Question about GE GSS25LGM Side by Side Refrigerator
Kenmore fridge will no longer get cold. temp change was over 24 hrs. ago. freezer and fridge are affected. how to remove coils for cleaning?
  • 415 Answers
Check to see if you have frost on the back panel of the freezer if so then defrost the unit and if your able to find the failure of the defrst heater or defrst thermostat,or the defrost thmer more than likely its the mother board since its a general electric frig but if you manually defrost until a repair tect can come then it will run normal until it frost up again but before you call the tech out make sure you have the frost on the back panel otherwise he'll make several trip trying to solve the problem with the frig unless its the defrst heater
Posted on Sep 08, 2009
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
Water leaks under viking professional and there is about a 1/4 inch build up of ice on floor of freezer(which is on the bottom) on the floor of the pull ot freezer
Your drain is plugged. Basically the freezer goes into defrost and melts frost off the condenser coils. A big piece most likely fell off and freezer came out of defrost before it coulld melt and drain out completely. To fix you have 2 options. Have towels
#1- move contents of fridge and freezer to a backup fridge. Leave unpluged with doors slightly opened for 24 to 48 hrs. Use towels to cleanup any water. Plug back in wait 2 hrs to make sure temp gets back down before putting contents back in fridge.
#2- Remove contents from fridge and put in ice chest. Have towels ready. Remove ice maker ( if there is one) usually two screws on top hard to see and one on bottom. Disconnect the quick connect for the ice maker. Remove screw on back wall. Be careful when removing air vent on back wall. Its plastic and can break. Remove back panel. Look on the silver plate under coils and you will see ice and where the drain is. Remove ice than pour hot hot water down drain until it flows freely into drain pan under fridge by compressor. It may look like there is not ice make sure othyerwise you will be doing this all over again in a few days. Once water flows freely put everything back together wait about 2 hrs for freezer temp to get cold enough and than you can put contents back in freezer. If you have any question or need help please feel free to comment me back.
Jun 05, 2011 | Viking Professional Series VCBB36 Bottom...
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Refrigerator not cooling but freezer works fine
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Kenmore Refrigerators
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
