Question about Music
Battery for GEM Promega 2
Had to send power board in for repair. They did not return the battery. I have only the pins where the battery or its adaptor fits. HELP. What type of battery and/or adaptor do I need? Need it fixed asap. Thanks!!
  • 62 Answers
Take it to a Battery World shop or a similar one that only deals in all types of batteries. They will solve it quickly. Or you could go to any of their websites and ask them the question.
Good Luck
Posted on Sep 13, 2009
Whre do I Send my Freehan music pro to get repaired the battery wll not chrge.
I had BatteriesPlus make me new battery packs for my 2 MusicPads. Cost was about $100 for both, 3 years ago. Be sure you match the power rating (4500mAh) of your original component batteries. The ones they had in stock were only 3500, I believe -- which would give you less time between charges. They had to special-order the 4500's. Each of the two packs takes 3 cells, which they solder together. I just removed the old packs from my MP, BatteriesPlus checked them, found the replacement equivalents, and made 'em up for me.
Aug 25, 2014 | FreeHand Systems Freehand MusicPad Pro...
Sound fades.
Did you try a new 9 volt battery?
Feb 22, 2014 | Marshall Amplification Marshall MS-2 Mini...
Does Allen-Heath Mix Wizard 16:2 (first generation) require Tip-Ring-Sleeve for Aux sends?
You should use TRS since that is balanced just like XLRs.
Especially for long wire runs. This is if you go for XLR on the other end =
Pin 1= Sleeve
Pin 2= Tip (HOT)
Pin 3= Ring
Normally, in US equipment, 2 & 3 are inverted (3 is HOT), but you got British here, they switch the HOT pin on the XLR to pin 2.
That means that if you run this unit with US speakers your signal will be out of phase. Be careful there... I have lived this with AH boards before.
You can also use normal unbalanced cable for short runs, but I suggest keeping to standards.
Dec 10, 2017 | Music
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
I plugged what i assumed was the correct transformer into my micro br and after a burning smell it died .obviously now i realise it was the wrong one ! unit does power on by battery still and works ok .is...
This was probably supposed to have a 5 volt power adapter... you burned up either:
1. Regulator
2. Circuit trace on the board
3. Protection diode
4. resistor ahead of the regulator.
Repair should not be too bad if they know exactly what you had connected, Make sure to use a competent shop.
May 06, 2011 | Roland Boss Micro BR Multi Track Recorder
Problem with the Yamaha AW 4416: My AW 4416 is warning "LOW BATTERY", i want replace battery but i don't see it (I opened the board AW 4416). Please help me! Thank very much.
The "battery" MAY be a soldered in type.
Here is your service manual:
http://elektrotanya.com/yamaha_aw4416.pdf/download.html
Scroll down on the web page to "Get Manual" and download the manual.
The battery is on page 153 in the manual at grid N-10... you are NOT going to like this... it is in a Dallas Semiconductor real time clock chip... You have to replace the chip. It is IC709 which is a DS12887 chip.
The physical location can be found on page 58 about half way down the "A" sectioning line on the right side of the page. It is a 24 pin chip... It MAY be in a socket, or maybe not... PRAY !
Wow... $11.12 each from digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=DS12887A%2B-ND
This info took me about 1 hour to dig out...searching for a battery was futile until I found the battery was related to the real time clock. If this isi soldered in, you need to have proper tools as the board is likely multilayer and takes care in solder removal... especially the new ROHS hi temp solders. You should take this to a board repair house if it is not socketed.
Apr 04, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
I have a behringer 16 channel board . the 2nd aux send in not working as of last week. What's the general problem that happens when an aux send stops working?.................
I don't believe this board has an "Aux send IN" jack. There are "Aux Send" and Aux Return.
The Aux returns are TRS jacks.
Make sure ALL interconnected equipment are powered from the SAME receptacle or source to avoid damage to equipment.
You might clarify the exact name of the in or out that is not working. I have schematics to help troubleshoot the problem.
Dec 18, 2010 | Behringer XENYX 2442FX Mixer
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
My 1604 VLZ Main Out bus keeps failing all the time, dramatically reducing the output level and also producing some noise artifacts. I usually have to put the levels to maximum course and it returns to...
is level pot defectives, needs to be replaced, u can change-them but is very comfusing, needs the same pot ref. u can find on electronics store, but probably dont find them easy, better send to repair. time spend to find them is long.
Jan 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
227 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
