Question about Samsung 52 in. Flat-Panel LCD HDTV
I have a Samsung 52'' LCD Touch of red 120hz (A650 model) and wanted to know if there were any recommended settings for picture that I can applies then tweek from there to my personal liking?
  • 92 Answers
If you enter the menu on the TV, go into Picture Settings and Choose "Dynamic".
Pick advanced settings, at the bottom of the menu, then you can alter the Gamma, Luminence etc to your Hearts content.
IMHO it is in the eye of the beholder what "they" want the picture to look like though, You have to choose.
Posted on Sep 08, 2009
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
I have a 5 yo 52" Samsung lcd.From a cold start it cycles on then off about 6 times before a picture comes on.I replaced capicitors and no difference. Whats next?
Most of the time only secondary large electrolytic capacitors are being renewed althoug small E. capacitors in a primary circuit of an smps (around the switching driver IC) can also cause this kind of issue. Although you say you replaced them i still believen its a bad capacitor.
Jan 29, 2015 | Samsung LN52A630 52-Inch 1080p 120 Hz LCD...
Television turns on and off automatic (or reset) 4 or 5 times before picture comes on, when first turning it on.
What you describe is an indication of a failing power supply. It tries to start but fails, then repeats startup.
Oct 28, 2014 | Samsung LN46A630 46-Inch 1080p 120Hz LCD...
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Feb 25, 2010 | Vizio SV470M LCD TV
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Red lines and seeing double image
First place to start is with the Main bd. Have a trained Samsung tech troubleshoot the set. Call 1-800-Samsung to set up a service call since your tv is a new model and is under manufacture warranty. Make sure you tell them you want a Samsung Field Engineer to repair your set. They are the most qualified and trained to fix your set.
Jul 08, 2009 | Samsung LN52A850 52 in. LCD HDTV
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Samsung 52 in. Flat-Panel LCD HDTV Logo
624 people viewed this question
Jerry Greenberg
Jerry Greenberg
