Question about DCS RGT-364GL Gas Range
Oven cavity not working
I just came from a dinner party where they had a DCS range that had a small fire recently due to over heated bacon flaring up. They were able to get the fire out but now there seems to be no gas entering the center tube to ignite and I am wondering if the igniter works at all. This is a very expensive unit and I'd like to investigate getting it fixed or repaired and idea of the damage. I am hoping there is a safety feature built in that can be reinstalled .
  • DCS Master
  • 2,558 Answers
It sounds like the fir ehas blocked the burner and the injector it needs checking out a god local gas fitter should be able to fix this
Posted on Jan 21, 2010
How do you repair oven that won't fire?
Given that its gas, I would advise you get a competent person to check it out. Propane gas and sparks don't mix. There are things in the owners manual you may feel confident enough to check, if not, leave it to a trained person.
Aug 29, 2014 | DCS Professional RDU485GDL 48" Pro-Style...
We have a dcs 48 inch range/oven and the main oven does not heat. The broiler does and the small side oven heats. Any advice?
You don't say if it lights up! If it lights up and stays on low it's the thermostat that's at fault, they are not adjustable and will need to be replaced.
Mar 09, 2014 | DCS 48 in. CP486GDSS / CP486GDSSL /...
OVEN CONTROLS AND OVEN DONT WORK. RANGE TOP WORKS FINE.
We're having the same problem. Oven light works, but plug by oven light switch does not. I changed the screw in fuse (15 Amp) in the oven, although it was blown, it didn't fix the problem.
I will be checking the double breaker on the electric panel tonight, making sure it's getting the full 220v, and if that is good, I will be looking at checking and replacing the clock.
Hope this helps.
Jan 10, 2013 | Frigidaire FEF366DC Electric Kitchen Range
Over the range microwaves have a piece of face plate inside and ive heard it has the tendency to catch fire. Why is that and what can i tell them to prevent the fire in the microwave.
When this happens, it is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
Keep the inside of the cooking cavity clean and if necessary, dry it out after use.
Jun 19, 2010 | Maytag Appliances Over-the-Range Microwave...
All 6 ranges and the large oven work well.the small oven won't li
My gas oven stopped working properly - called in the repair man and he replaced two of the three ceramic ignitors. (I have a two oven model). Apparently they only last / work well for 3-5 years. Kinda sounded crazy to me - but verified on the internet they are required to be replaced. Not sure I'd call the repair man next time - get the part yourself, one screw & two wires to replace. I'm no expert - but that solved my problem.
May 22, 2010 | DCS RDS-486GD Stainless Steel Dual Fuel...
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Range works, oven doesn't
We have a very similar problem: "Ready" light comes on immediately when turning on oven/broiler but oven does not heat up.
Mar 16, 2010 | DCS RGT-305 Gas Kitchen Range
Oven stopped heating half way through fixing dinner tonight.
check ur bake element turn of power, remove 2 screws from back wall that hold it on,, pulll out dont drop wires back into cavity check the element with a continutiy tester meter for open/closed if it reads anythin it is good if nothin occurs replace the element usually under 50 dollars at a local shop, prob pay allot more over the internt after shipping .. hope this helps take care
Jan 28, 2010 | Whirlpool Accubake RF362LXTS Electric...
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Broiler not working, Oven OK
We have a DCS RG-366 SS L, a 36" gas range and the igniter went out. You could smell gas and the igniter would glow red - but no fire across the broiler.
There is a place in Michigan called RepairClinic.com. We bought a replacement igniter from them and it works like a charm. It was $53 (we live close by and didn't have to have it shipped).
The item number (from the invoice) is 1191 and the box the igniter came in looks like it is manufactured by FSP, code 082005, and there is a larger number on the box that says 786324 IGNTR-OVEN.
Hope this helps.
Sep 13, 2008 | DCS RGS-305 Professional Gas Kitchen Range
DCS RGT-364GL Gas Range Logo
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
