I am seeing two of everything. I have tried to use the converge feature, but I cannot get everything to line up. It only allows you to go so far with the red and the blue. What should I do now?
    Problem Solver:
  • 11 Answers
Easy fix.
you need to replace the two convergence chips that are attached to the heat sink.
they are the two identical chips next to each other with a lot of legs on them.
Posted on Sep 08, 2009
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
My 52 inch RCA projection tv has a blue line around everything white
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
Feb 10, 2013 | RCA R52WM24 52" HDTV Projection Television
Replaced convergence ic's and picture is good but still no blue color to adjust in the convergence mode. the blue bulb is lit in back.
You may have pressed a wrong button when in service mode---it allows among other things to turn individual colors off like Blue--to make it easy to adjust red to green first.
Also take a look with set on into the Blue lens to make sure you have a image and it does not look like a blue flood light.
a last note: if you tampered with the lens (they have a wing nut on side that allows them to be turned you may have on the blue turned the lens so far there is no focus---for that lens--Did you?
May 30, 2012 | Samsung HCN4727W 47" Rear Projection...
IMAGE GHOSTING
Have you tried the auto converge or flash focus adjustment? This feature allows you to adjust the convergence automatically. If it doesn't work,convergence circuit is faulty. You need to replace the convergence kit, To do this you need some basics on electronics.
Feb 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
My phillips 60 in projection tv is showing to
The two convergence ICs and 12 feed resistors are the most likliest cause. Whats your model number as you can get convergence repair kits which have parts and CD with instructions at www.tvrepairworld.com
Jul 16, 2009 | Televison & Video
The tv is showing everything kind of double and everything is double lined in red and green
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Have a sony kf-50xbr800 rear projection tv. Has red line definition on many object but particulary on long or far shots. Tried the service menu recommendations d-gm tg v pos and it didn't correct the...
Hi...
I would try the Convergence setup in the service menu ( IF they allow you to do that)
If the internal convergence isnt enough you might have to have the convergence amps replaced
Jan 02, 2009 | Televison & Video
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Akai 4298 projection tv
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Hope this helps ...
Aug 29, 2006 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
