Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Electric Range Oven turns off "POWER INTERRUPTION"
Model # MER6870AAC purchased in 2001 When I turn the oven on...it will turn itself off at varying times...Message will appear on the screen by clock "power interruption" and then screen will go blank. Sometimes the screen will turn on again. Burners work and their power is not interrupted. I may not even have oven on and the clock will just go out and I will have to reset. This occurs when I use either oven and when I use convection or regular setting. Last year I did have repair done with the latch because I couldn't use the self-cleaning mechanism.
Hope you can help!
Thanks
4 Suggested Answers
  • 2558 Answers
SOURCE: Power Interruption
power interuoption is a power cut / power went off it needs resetting your tech should be able to do this
Posted on Jan 22, 2010
  • 219 Answers
SOURCE: Power Interruption on Jenn Air Slide in Range
replace your erc
Posted on Mar 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: After a recent power interruption the Electronic
These electronic controls are very sensitive to power surges. I am afraid your control is now bad and must be replaced.
There are no fuses or reset buttons.
Posted on Nov 13, 2009
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Power Interruption
Jan 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bottom oven heating element turned white hot and broke in the middle. Can I replace myself?
This is a common problem and easy repair. Locate the model number onside the oven door frame. Purchase the element based on the model number. TURN OFF the power to the oven. Unscrew the 2 screws inside the oven holding the element to the back wall. Gently pull the element forward. The wires will be short.Remove the wires from the broken element. Place them on the new element. Re-insert the element terminals and attach the screws.
TURN ON the power. Bake me some cookies and send them to me.
Jul 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Display Malfunction
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Oct 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Oct 06, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
297 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
