Question about Panasonic TH-37PD25U/P 37 in. EDTV-Ready Plasma Television
Panasonic Plasma Viera - screen is 3/4 and then a 1/4...split. what do I do??
I lost picture on main scream in panasonic th-37 pd 25 ,what i can dothanks
Posted on Jun 27, 2012
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
dsacco86
  • 1077 Answers
SOURCE: what does it mean when my plasma tv turns off by
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Posted on Nov 02, 2009
Why is my screen split
The split is it along the vertical or horizontal? Cos either of this is bad or the flex connected to the screen.
Aug 26, 2014 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic viera 37" plasma.....screen is turning green wid splitting colors n bad picture
U may have kept a speaker close to it. Don't keep speakers close to t.v #visit electronic store for repairs.
Sep 03, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
How do u do a split screen
The Panasonic Viera does not have a split screen/picture in picture feature. So I'm afraid you can't actually do that.
Mar 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Is there away to split scrren on a42 in. panasonic viera
Hi
If you do not have PIP ( Picture in Picture ) then i would say this is not possible.
You would have to check your user guide which if your tv does have this function will tell you how it is done.
If you dont have the user manual then you can download it here......
http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX80U
Hope this helps
Apr 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic viera with vertical lines down the screen which change colour randomly
Either the buffer board is bad or the plasma panel,sometimes it coult be bad connections on the interconnect ribbon cables from the plasma panel to the buffer boards.
Mar 19, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Replace screen
This is a plasma panel and the part number is: MD65F10A1J and the cost is $3387.95 with a refund of $200 when the bad panel is sent back.
Dan
Mar 22, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TH-37PD25U/P 37 in. EDTV-Ready Plasma Television Logo
418 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
