Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Unit will not power up. Plug it in, Green light blinks 3 times, then dead. Been reading about replacement capacitors on the DM board. Where do I find this as I can do this work by myself? Seems to be a common Mitsu problem.
  • robschanilec Sep 09, 2009
    What I was asking is where do I find these capacitors and/resistor you are discussing.
  • robschanilec Sep 13, 2009
    If it were a resistor, where would it be? Could it be a fuse also?
  • Mitsubishi Master
  • 8,457 Answers
Tries these websites Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Posted on Sep 19, 2009
    Problem Solver:
  • 11 Answers
If it were the capacitors they will have exploded on the top or bottom of them.
probably a resister.
Posted on Sep 08, 2009
Mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
Blinking light of death wd-52725 blinks green wont turn on replaced 4 16v 1000uF caps on dm board no luck! maybe need to replace more on board? plug in hit reset and only here something clicking on dm...
Please let me know if you can get any sound at all out of your unit.
solution
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
Green power light keeps blinking
hi friend,
Repairing It Yourself
If you decide to repair the TV yourself, I recommend that you obtain a copy of the repair manual for your Mitsubishi TV from the Techlore website by going to Mitsubishi Service Manual. It will provide some direction, however it is technically written and may be difficult for the NOVICE to understand. If you are unable to locate the the service manual for your specific Model at the above Techlore link, you may need to purchase the service manual online at ServiceManuals.net.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
A Few "Cautions"
  1. Keep yourself "grounded" when working with the circuit board. Static electricity will destroy electronic components.
  2. When replacing the Capacitors, press them "down" onto the circuit board as far as they will go, hold them down, solder into place and clip the excess terminal lengths flush with solder. Only by doing this will the metal shield (little silver box) slide down and over the circuit board during re-assembly. There is not a lot of clearance when doing this, as the 105C Capacitors are slightly longer that the originals. With minimal effort everything does fit back together.
  3. Use ONLY 105º C capacitors with a voltage rating of 35 V.
  4. Re-insert the DM circuit board into the Mother board; press virmly and ensure a proper seat of the DM board. Next, slide the metal case down and over the DM circuit board. Refer to my "Lesson Learned."
Basic Troubleshooting
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mits 525 started blinkng green standby light today makes a muffled sound as it beeps. wont turn on just beeps.just under 4 yrs old. have replaced bulb 3 times. reading some of these posts seems like...
The first generation mitsubishi V26 chassis which is what your model is has a bad habit of failing capacitors. The steady blinking green power light is related to the DM not completeing the boot up sequence. You can get the V26 DM repair kit at the following link which contains the replacemnent caps that are prone to fail and has the CD with step by step instructions on how to duisassemble the cjassis and replace the caps. Its very inexspensive and will usually repair that issue. Its listed under the repair kit category.
Mar 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
