Question about Sharp XL-UH270 Shelf System
Time How do you keep the time on permanently when in standby mode?
  • n3il Dec 09, 2007
    No i dont unplug the stereo i just leave it on standby, if i press the clock/timer button on the remote it will display the time for a short period, but I want it showing all the time.
  • 151 Answers
Don't unplug the unit... That keeps the time on all the time, and it consumes less power. I hope I didn't misinterpret your question...
Posted on Dec 09, 2007
  • Chris Montano
    Chris Montano Dec 09, 2007
    There is no known setting to display the clock permanently on this model, it just displays it for 10 seconds after pressing the remote clock/display button...
Sleep mode
A Google search indicates this is a common problem.. Some of the comments in this video may help. If it is still under warranty, you might be best to get a RMA. Good Luck.
How to fix Samsung monitor that is stuck in sleep standby mode Temporarily
Oct 26, 2017 | Samsung BX2450 LCD Monitor
All nokia secret codes
Tips / undocumented functions:
- At the top of the main-menu and every folder, the keys 1 to 9 are shortcuts to the icons 1-9
- A shortcut on the left menukey in standby-mode will take more time to open than a shortcut on the right menukey. Reason: The left key is also used for the keylock so it shortly waits for pressing the * button.
- While writing text press and hold "#" to switch between Alpha mode and Number mode. You can also press a key long to insert its number.
- In standby-mode, press and hold 0 to launch your wap home page.
- If you have your keylock activated just press the on/off button to turn on your backlight to look at the time when it's dark without having to unlock the keypad.
- To keep the backlight on, run Torch (freeware), press and hold the Menu button and go somewhere else on the phone.
- To check your current firmware version simply type *#0000# in standby screen.
- To check your IMEI (International Mobile Equipment Identity) type *#06# in standby screen.
- To check your Bluetooth device address type *#2820# in standby screen.
- Start up in Safe Mode (no 'auto start' apps will be running): Hold down the pencil key when you turn on the phone and hold it on until you have to enter your PIN code.
- Format the phone memory by typing *#7370# in standby screen.
- In standby mode,
45# + <talk> dials the number on your sim in memory slot 45.
50# + <talk> dials slot 50 and so on
on May 12, 2010 | Cell Phones
How to set the time
How to set the time on what make and model device?
Mar 01, 2013 | GPS
Sony KDL-46z4100 standby light blinking 12 time with few seconds gap continiously
12 blinks of standby light indicates 'Scanrate error'. You must have thorough knowledge in electronics to proceed. Actually, this is not a user repairable fault. it is very skilled work.
Jul 09, 2012 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
Restarts Unit/Clock Every time car turns off
Hi the problem is due to it been wired in wrong their should be two live wires coming from the unit one is permenant live this stores the time and any setings you change and the other live is main live that turns the unit on when ignition is on.
What you need to do is locate these live wires they will either be wired up to one live wire coming from the car this causing the problem you need to have one live wire going to live auxilary and the other should goto a permanent live wire.
The permanent live wire is the one that stores the time and setting etc it usually an orange wire and the permanent live wire is usually red.
What you can do is use search engine and look for wiring diagramme for your unit this will show you whats permanent live and what aux live hope this is some help.
If you are unsure let some one look at it for you its only five minute job thats all ok
Feb 26, 2008 | Car Audio & Video
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Bulb Reset issue
I had the same problem and called Sony, they just said to keep trying what the manual says to do, but make sure the unit is in standby mode. I tried in powered mode and in standby mode many times and it did not work. Then I tried again the next day when the unit had been in standby mode for an extended time period. I hit the four buttons like the manual said, all four in quick succession. I also tried the four buttons in many different sequences from what the manual said. When I powered back up the lamp timer was set to zero, finally! I think having the unit in standby for an extended time was the key. The Sony rep really emphasized the need for the unit to be in standby.
Oct 01, 2007 | Sony VPL PX40 Multimedia Projector
Lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Sep 27, 2007 | Televison & Video
Sharp XL-UH270 Shelf System Logo
53 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
