Question about LG DLE3777 Electric Dryer
I have a lg dryer model # DLE3733W. it drum is making a rattleing noise? I would guess something has came loose or the rollers need to be replaced. i have figured out how to get the top off and can see the drum, but how do you get the front off to get to the rollers? Are there two rollers and does this sound like it may be my problem??
  • pjdrobeck Sep 08, 2009
    How does the bottom part of the face come off? I have taken off the top screws and have managed to pry the top art of the face away from the dryer, but the bottom is hung up. I do not want to force it. This dryer is on a pedestal, do i need to remove it first?
    I found a large peice of lint in the blower fan. I am sure it is the problem. thanks
  • 10,515 Answers
This model shows 2 styles - on your, you will have to remove the top and then take the screws out holding the Control Panel and remove it but leave it hooked up and then take out the screws holding the front panel on and take off. You will find a lot of lint in the blower that is making it out of balance and if not you will need to replace the tub rollers.
http://c.searspartsdirect.com/lis_png/PLDM/50030503-00002.png
http://c.searspartsdirect.com/lis_png/PLDM/50030503-00003.png
The above would be the diagram that would help you.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
The dryer is making a squealing noise when tuning like something needs to be lubricated
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Feb 21, 2015 | Dryers
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
Maytag Dryer vibrating and rattle noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Aug 17, 2014 | Dryers
Rattling noise, as if motor assembly is loose on LG DLE2701V dryer
drum rollers,drum glides,motor mount or belt idler assembly, all these items can be found on eBay. note the routing of the belt, the idler assemblage is next to the motor. this website shows the rollers/glides, hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Nov 27, 2010 | LG Dryers
My lg dle3733w dryer is vibrating a lot
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 19, 2009 | LG DLE3733 Electric Dryer
Thumping sound from loose drum
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Neptune gas dryer rattles sporadically when running.
do you fell it rattleing alot? Its can be the rollers are very worn and need to be replaced or the center of the rollers need to be greased up. hope this helps...
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
LG DLE3777 Electric Dryer Logo
70 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
