Question about Acer TravelMate 2300 Notebook
Orbicam Problem Hi Guys, having trouble using my orbicam for yahoo messenger, working as it is off line but when i am using it for YM it just doesn't work. your help will be highly appreciated.
  • FUCKME Dec 22, 2007
  • 128 Answers
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Posted on Feb 02, 2008
  • 97 Answers
Its a camera ofcourse it works offline, but it is built to use with windows live messenger and not with yahoo
Posted on Jan 10, 2008
Acer's built in webcam
Take your laptop to your local computer repair shop, as it will take too long to explain a solution.
Good Luck.
Jan 22, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Seeing it used to work, have you tried doing a System Restore? If you can remember when this started happening, you may be in luck. Just hold down your Windows key (usually between the CTRL and ALT keys on your keyboard) and hit the PAUSE-BREAK key. Then, click on START | PROGRAMS | ACCESSORIES | SYSTEM TOOLS and choose System Restore. If you have a restore point around or before the date this problem happened, click on it and let it go through its steps. Try that.
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Aspire 5610-2762 Orbicam not working
Ready for this, goto to start>my pictures and remove all images from that folder except for the samples folder, just create another folder in your documents for these images.
Now start the webcam up again.
Sounds stupid but it works.
Jun 16, 2008 | Acer Aspire 3680 Laptop
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Acer 5630 orbicam
press ctrl + alt + del one after the other but holding them down in that order, check what programs may be running or using it, if you see what is using it, go to run (in start menue), type services.msc hit enter then look for that program and disable it, that way it wont be able to use it again.
Apr 13, 2008 | Acer Aspire 3690-2196 Notebook
Acer orbicam
First u remove the orbicam drivers and restart.After windows booting,u insert orbicam driver cd and instal it.After installation completed,once again u restart the laptop.
Feb 25, 2008 | Acer TravelMate 3260-4874 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility
These can be found here under the MS Windows Vista drop down menu:
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Orbicam for yahoo messenger
will just try to remove from the control panel using add/remove program to uninstall software...then after removing you must install it again.. maybe your YM is corrupted....
Dec 09, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
