Question about Dryers
Dryer doesn't turn on - Maytag Performa PYE2200AYW
There was a burn smell like the motor was being overworked. I went to check the dryer and it had turned off. Overheated? Fuse? I cleaned the exhaust pipe in the back, checked the breaker, checked the plug, checked the door - all seem fine. It still doesn't turn on. It is 6 years old. Is it time to get a new dryer?
  • Dryers Master
  • 8,220 Answers
Some repair photos
Posted on Sep 08, 2009
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
Maytag performa dryer model #PYET344AYW wont stay running
Yes, I suspect the motor is at fault. The motor you need is available below!
Motor <----- CLICK HERE FOR THE CORRECT PART FOR YOUR MODEL
Aug 23, 2012 | Dryers
Maytag Performa PYE2200AYW drum turns until I put clothes in it, then it slows and stops.
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to
May 29, 2012 | Maytag Dryers
When turning on dryer you here a humm noise like the engine is trying to turn but it wont and shuts down. And smells like electrical burning. took apart to see if belt not belt nothing jammed.
sounds like you have a faulty motor burning smell means overheating or shorting could also be faulty wiring or control you should cal an appliance serviceman good luck let me know how you went
Nov 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start and smells like something is burning
I'm having the exact same problem verbatium! did you ever figure it out. I already replaced the motor and the belt, but it's still doing the same thing.
Feb 17, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Electric Dryer, model # PYE2200AYW.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Oct 18, 2008 | Dryers
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Performa PYE2200AYW - not working
Yes there is a fuse in the dryer. The black circular thing is a high limit thermostat. Beneath it is the thermal fuse. It is smaller (dime size) and is mounted to the right side of the heating element housing. It is alittle tough to see and get at. You must use the original Maytag part kit.It comes with a new high limit therm. and fuse.
Oct 19, 2007 | Maytag Performa PAV2200
Dryers Logo
213 people viewed this question
Top Dryers Experts
