Question about Lexmark X3470 All-In-One InkJet Printer
My printer had a paper jam. i got the paper out, but now i can't get the ink cartidge to go all the way across. the bar that allows it to move, one of them has fallen down. how can i fix it
  • 52 Answers
Dont try to fix it yourself call a service engineer to do so.
Posted on Sep 08, 2009
Cartidges wont move
the cartridge as you call it is the carriage, which houses the inks and printheads, Its supposed to be 'Locked' at the service station until such time as the printer is ready to start printing,
what you should look for is a strip of what looks like clear plastic that runs the lengh of the print surface, give this a GENTLE clean with a cloth damped with WATER, ensure there is no paper blockage along the print path the cycle thhe power allowing the machine to come to ready or fault displayed
Mar 09, 2014 | HP OfficeJet Office Equipment & Supplies
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Getting black streaks across documents and pictures
Usual cause is defective bllack cartridge or it needs to be removed and excess ink cleaned from the face of it.
SOMETIMES using too heavy of paper can bend up an touch the bottom of the cartridges as tehy move across to page.
Also a paper jam can brush the cartridge and after that the ink is smeared on the cratridge face and will mark the paper as it moves across.
Using BAD refilled cartridges is a common problem.
Nov 08, 2009 | HP Photosmart C6380 All-In-One InkJet...
Paper jam
Found this on the HP Web site.
Issue:
The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK ' displays on the product.
HP Support
GOOD LUCK!
Oct 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a carrier jam on my dell 944 printer
Printers have small paper flags (plastic levers) that tell the printer where the paper is, also if the motor that drives the inks up and down the metal bar inside cannot turn (due to an obstruction) you will get carriage jam. Open the lid and check the ink carriage moves up and down freely (maybe the ink cartridge has popped out slightly).
Also see if you cand see these little flags and make sure they move up and down ok. Sometimes they work on a tiny spring that pops out.
If there is no obstruction and you can move the carriage by hand (with the power off of course) and it still says carriage jam then i always have a lot of luck by lubricating the carriage bar (shiny steel bar) with some WD40 or other oil.
Hope this help.
Cheers!!!!!
Jul 23, 2009 | Dell 924 All-in-One InkJet Printer
What is wrong when the second light from the top is blinking?
Check there is not any paper jam. pull the ink cartidge and refix it if you have other ink cartrdge try with it.
Also check in back side of printer there is not any paper jam.
Jul 13, 2009 | HP LaserJet 1320 Printer
I have an error code 5100 on a Cannon MX310 that will not allow me to print. Can you help please?
There are several things to check
1.remove and reinstall the ink cartidges
2. press ON/OFF switch to reset the printer
3. if the printer is new, make sure all the packing material has been removed
4. Check the paper path to make sure that you do not have a paper jam.
5. If these do not clear the problem, you need to have the printer serviced.
2. 3. Remove Packing Material MX310 4. Removing paper jams MX310 5. The MX310 may require repair
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Lexmark X3470 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
