Question about Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
Ice Maker Same thing...doesn't make ice!!
    Sergeant:
    Champion:
  • 255 Answers
Move arm to down postion. defrost and clean ice maker, ice jam
Posted on Sep 08, 2009
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
How to diagnose ice maker does not produce ice
The first thing to check is to make sure that the temperature in the freezer is below 10 degrees F. If not the ice maker will not work because the sensor in it won't allow it to call for water. If the temperature is good, check to see if there is ice in the ice maker.If there is and its not dropping ice then more than likely the mold heater which allows the ice to break free and thus be ejected has gone bad and you need to replace the ice maker. If no ice is there check the fill tube to make sure there is no obstruction, and if not turn the ice maker off, wait a minute, then turn it back on, When you do that a small amount of water should initially come in. If it doesn't then the water valve itself has failed. Also a note, check the water filter to make sure its not old, this too will also cause water not to come into the machine but you'll notice this also in the water dispenser area as well.
Sep 05, 2012 | GE Profile PDS22SFS 22.2 cu. ft....
How do you reset Ice maker module
put the metal arm down to turn it on or pop off the cover and with a jumper wire stick it into the T and H,the ice maker motor should start to run,pull out the wire after 20 seconds.if it doesn't start you have a bad ice maker.
Sep 02, 2012 | Kenmore Side by Side Refrigerator
MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker doesn't dispense ice
The most reasonable things could be that the gas ran out; the buttons and thermostat don't work; power issues; or you might have a leakage on the gas pipe.
Try calling a fridge/air condition technician to verify this.
Nov 23, 2011 | Frigidaire FRS26RBCW Side by Side...
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not making any ice.
Hello there:
here is a couple of things to check ok
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 23, 2009 | Refrigerators
Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
149 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
