DVD GO FORWARD BY ITSELF - Audio Players & Recorders
  • 2,200 Answers
Hi
This problem is caused when the optical drive fails to read the DVD accurately and this causes it to skip forward.
The most common cause of this is dirt on the laser lens. You should try a DVD laser cleaning disk which you can purchase at any good Audio store. It just inserts into the DVD as normal and plays like a normal disk but it performs a cleansing action on the lens as it operates.
You can also clean the lens by opening the case and using an alcohol solution with a Q-tip to gently clean remove any residue from the lens that may be causing the issue.
Remember - Safety First! If you decide to clean the lens by opening the case - please ensure that the unit is completely disconnected from its power supply.
If these actions fail to resolve the issue then the drive itself is misaligned and will require service attention as this is not a user serviceable issue.
Hope this helps. Please do rate my answer. Many Thanks.
Posted on Sep 08, 2009
How to fix the CD/DVD Player which skips back and forwards during playing track3?
it may not be your cd or dvd player, it may be that you have a defective disc or scratched so try taking a damp paper towel and wiping it off real good and then take another one and dry it and then try playing it again and if that don't work then it could be something within the player itself. I hope that this may be of some help to you, good luck,
Aug 19, 2014 | Televison & Video
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
How do you program into the dvd that you want it to fast forward quickly? There is a way but am not sure how it is done.
You don't, you just press the FORWARD button on remote during DVD playback to 'fast forward' (pressing this button a second time during playback increases forward scan speed). The forward and reverse buttons have 'SLOW/SEARCH' printed above them on the remote. The other buttons next to them are the PREV/NEXT buttons (SKIP/INDEX).
DVD playback speed/skip/search is mostly a manual user function; it cannot be auto set.
May 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
When watching a dvd it starts beeping and skipping. i noticed that when i put it on the radio, the radio starts scanning and when it gets to a channel with pretty good reception it will stop on that...
Hello,it sound to me like you have a (skip) forward button either on the remote control or the units front panel stuck . Remove the remote from the room and see if it continues,if so than look closely at the skip forward button on the unit itself.
Feb 10, 2011 | Samsung Htbd1250 Blu Ray Home Theater...
Tried to use a laser lens cleaner disc to clean my player, once loaded and inside the player I went to press play and follow the instructions, but my player stopped running and a (check disc) appeared on...
I have this DVD Cleaner from All sop Inc as well,this disc only do very miner cleaning to the DVD player Laser eye.Did not work on my DVD player.I have to take the DVD player aparts,littery take some Q tips and dips it in with some rubbing alchahol to clean the DVD laser eye itself.After littery take the DVD player aparts and clean the laser eye itself.If the DVD player still doesn't read and play any DVD discs?The DVD player laser eye is bad,not worth repairing,the brand new DVD player is cheap,cost only like $40 brand new one.
Nov 23, 2010 | LG DN798
Do you mean DVD jumps / skips forward in playback?
If yes, please clean optical laser lens in player. It sounds optical lens has thin layer of dust and causing ' tracking error ' in playback.
Put CD Lens Cleaner disc in player and press play to clean optical lens by cleaning disc and if problem still exist, need to clean lens manually with good quality cotton bud.
Hope this will solve your problem.
Thanks.
Sep 08, 2009 | Samsung HT-Q100 System
We had no control of the DVD that we watched last night. No pause, fast forward, etc. Tonight, trying to watch another DVD and the one from last night continues to be playing and will not eject. Neith
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
May 27, 2009 | Televison & Video
Remote problem
Hi There,
On the front panel:
REV Button (DVD)
Press to view the DVD picture in fast reverse motion
or to reverse playback of an Audio CD.
Press to skip Chapters or Tracks.
FWD Button (DVD)
Press to fast forward the Disc. Press PAUSE, then
press this button to begin slow motion playback.
Press this button repeatedly to change the forward
speed of slow motion.
I hope this helps,.
If not, feel free to conact me.
Thanks,
Mike
Nov 03, 2008 | Emerson EWD2203 DVD Player/VCR
Possessed
Dear lost366,
The problem lies with micro IC (cpu IC) . This has to be replaced. Please contact authorised service centre.
Jun 15, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
18 people viewed this question
 Grubhead
Grubhead
