Question about Kryptonite Kryptoflex 1218 Combo Cable Bike Lock
Mounting the bracket - Kryptonite Kryptoflex 1218 Combo Cable Bike Lock
    Problem Solver:
  • 11 Answers
Weld it or super glue it
Posted on Sep 09, 2009
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Where is the ignition module on a 99 plymouth voyager
Also called Ignition Coil, is located at the back of the intake manifold...
Fig.: remove the 2 lower ignition coil mounting bracket bolts...
Fig.: then remove the ignition coil and mounting bracket together from the engine.
Disengage the wiring harness connector from the ignition coil.
Disconnect the ignition wire from the coil.
Remove the coil mounting bracket bolts, then remove the coil and mounting bracket assembly from the vehicle.
The ignition coil can be separated from the mounting bracket.
To install:
If separated, loosely mount the ignition coil to the mounting bracket.
Loosely install the coil and mounting bracket assembly to the intake manifold. Tighten the coil mounting bracket-to-intake manifold bolts to 115 inch lbs. (13 Nm) and the ignition coil-to-mounting bracket fasteners to 96 inch lbs. (10 Nm).
Connect the ignition wire to the coil.
Engage the wiring harness connector to the ignition coil.
If removed, install the windshield wiper/motor module assembly.
Connect the negative battery cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 10, 2012 | Cars & Trucks
Where is the ignition module in a 99 voyager
Hi Eric:
To install:
Feb 10, 2012 | Plymouth Cars & Trucks
How to remove a radiater from a 2000 oldsmobile silouette?
  • Remove air cleaner and duct assembly.
  • Drain coolant into a suitable container.
  • Loosen engine mount strut to engine mount strut bracket bolts.
  • Loosen engine mount strut bracket brace bolts from upper radiator support bracket.
  • Remove mounting bolts on radiator upper support and position engine mount strut and bracket to rear.
  • Ensure ignition switch is in Off position, then disconnect cooling fan.
Thanks
May 20, 2011 | 2000 Oldsmobile Silhouette
Ok i dropped the motor now its still a cross line i have to get past before the belt is install any suggestions
REMOVAL
  1. Remove the following components.
    1. The engine mounting bracket lower nut.
    2. The engine mounting bracket lower stud.
    3. The engine mounting bracket lower spacer.
  1. Remove the belt.
INSTALLATION
  1. Install the belt. Install the following components:
    • The engine mounting bracket lower nut.
    • The engine mounting bracket lower stud.
    • The engine mounting bracket lower spacer.
It really is that easy.
Jan 29, 2011 | 1997 Buick LeSabre
How to change serpintine belt for 97 buick le sabre
These were a real pain in the neck to change, you may want to take it to a shop if you don't have a lot of experience. The hassle of doing it yourself may outweigh the cost.
Here's the procedure, but it is easier said than done:
REMOVAL
  1. Remove the belt.
INSTALLATION
  1. Install the belt. Refer to Engine Mount in order to install the following components:
Jan 23, 2011 | 1997 Buick LeSabre
How to change the alternator on my 2000 grand voagear
This is for a 3.3L motor
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
REMOVAL
  1. Release hood latch and open hood.
Removal/Installation of Battery Cables 81929864
  1. Disconnect battery negative cable.
  2. Remove windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  3. Remove accessory drive belt.
Generator Mounting Bracket 81929870
  1. Remove bolt holding top of generator mount bracket to engine air intake plenum.
  2. Remove bolts holding outside of generator mount bracket to generator mount plate.
  3. Remove bolt holding top of generator to mount bracket.
  4. Remove generator mount bracket from vehicle.
  5. Rotate generator toward rear dash panel.
Generator 81929868
  1. Disconnect the push-in field wire connector . from back of generator.
  2. Remove nut holding B+ wire terminal to back of generator.
  3. Separate B+ terminal from generator.
Generator Pivot Bolt 81929871
  1. Remove bolt holding bottom of generator to lower pivot bracket.
Generator 81929872
  1. Remove generator from vehicle
INSTALLATION
  1. Place generator in position on vehicle.
  2. Install bolt to hold bottom of generator to lower pivot bracket.
  3. Place B+ terminal in position on generator.
  4. Install nut to hold B+ wire terminal to back of generator.
  5. Connect the push-in field wire connector into back of generator.
  6. Rotate generator forward away from dash panel.
  7. Place generator mount bracket in position on vehicle.
  8. Install bolt to hold top of generator to mount bracket.
  9. Install bolts to hold outside of generator mount bracket to generator mount plate.
  10. Install bolt to hold top of generator mount bracket to engine air intake plenum.
  11. Install accessory drive belt.
  12. Install windshield wiper housing, refer to the Windshield Wipers and Washers for proper procedures.
  13. Connect battery negative cable.
  14. Verify generator charge rate.
Jan 02, 2011 | 2000 Plymouth Grand Voyager
I cannot get the alternater out of my 1997 Dodge Grand Caravan. It is a 6 cylindar 3.3 engine. The Chilton manual is no help at all. I have managed to remove all the bolts holding it on, but I cannot even...
3.3L & 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the windshield wiper/motor module assembly.
  3. Remove the accessory drive belt.
  4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
  5. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
  6. Remove the bolt securing the top of the alternator to the mounting bracket.
  7. Remove the alternator mounting bracket from the vehicle.
  8. Rotate the alternator toward the dash panel.
  9. Unplug the push-in field wire connector from behind the alternator.
  10. Remove the B+ nut and wire from behind the alternator.
Alternator removal-3.3L and 3.8L engines
  1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  2. Remove the alternator from the vehicle.
To install:
  1. Install the alternator into position on the vehicle's engine.
  2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
  3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  4. Plug in the push-in field wire connector onto the back of the alternator.
  5. Rotate the alternator forward away from the dash panel.
  6. Install the alternator mounting bracket in position on the vehicle.
  7. Install the bolt to secure the top of the alternator to the mounting bracket.
  8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
  9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
  10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
  11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  12. Install the windshield wiper/motor module assembly.
  13. Reconnect the negative battery cable.
  14. Verify the charging rate of the alternator.
LET ME KNOW IF THIS HELPED.
Oct 18, 2009 | 1997 Dodge Grand Caravan
Silverado 1500 Z71 off road, 5.3L. Details on fr
This is for the front: Removal & Installation
  1. Remove 2/3 of the brake fluid from the master cylinder.
  2. Remove or disconnect the following:
    • Wheel
    • Caliper. Suspend the caliper from the frame with mechanic's wire. Do not allow the caliper to hang from the brake hose.
    • Caliper mounting bracket bolts
    • Caliper mounting bracket from the steering knuckle assembly
    • Brake pads from the caliper mounting bracket
    • Clips from the inside ends of the caliper mounting bracket and discard
To install:
  1. Install or connect the following:
    • Clips to the inside ends of the caliper mounting bracket
    • Brake pads to the caliper mounting bracket
    • Inner pad (1 wear indicator)
    • Outer pad (2 wear indicators)
    • Caliper mounting bracket to the steering knuckle assembly
  2. Perform the following procedure before installing the caliper mounting bracket bolts:
    • Remove all traces of the original adhesive patch.
    • Clean the threads of the bolt with brake parts cleaner or the equivalent and allow to dry.
    • Apply red Loctite®272 to the threads of the bolt.
  3. Install or connect the following:
    • Caliper mounting bracket bolts to the steering knuckle. Tighten the caliper guide pin bolts to 74 ft. lbs. (100 Nm) on 15 series or 80 ft. lbs. (108 Nm) on 25/35 series.
    • Caliper
    • Tire and wheel assembly
  4. Refill the master cylinder to the proper level with fresh brake fluid. Pump the brake pedal slowly and firmly in order to seat the brake pads. Burnish the brakes as needed.
Oct 12, 2009 | 2003 Chevrolet Silverado 1500
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    Kryptonite Kryptoflex 1218 Combo Cable Bike Lock Logo
    177 people viewed this question
    Top Kryptonite Cycling Experts
    luminos8
    Level 1 Expert
    John Egan
    John Egan
    Jack Hunter
    Are you a Kryptonite Cycling Expert? Answer questions, earn points and help others
