LaCie Rugged All-Terrain  Hard Drive
Problem for LaCie Rugged All-Terrain (301017) Hard Drive
Doesn't recognize my disk
By mroson on Sep 08, 2009
Best Solution
posted on Sep 08, 2009
Very Helpful)
bob_computer
Rank: Guru  LaCie Computer Accessories  Expert
Rating: 87%, 1258 votes
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LaCie Rugged All-Terrain Hard
Questions and Unsolved Problems for LaCie Rugged All-Terrain Hard
Do you recommend LaCie Rugged All-Terrain (301017) Hard Drive?
Answer
Answer
I just want to use it like a flash drive. Why is that so hard to do? I told it not to install... (More)
Answer
can any one tell me the brief procedure of how to connect two hard disks to one computer i.e how... (More)
Answer
Bought this new drive and plugged into my firewire - did not even recognise it! I thought there was... (More)
Answer
'rugged' hard drive wont search. I type in the 'search' spot, and nothing comes up. It worked... (More)
Answer
It doesn't mounted into my Dell Latitude D630 notebook. I just bought new All terrain 120 GB hard... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
