Question about Cycling
My schwinn 3 speed autoshift doesn't work properly. When I encounter a hill it shifts down but then almost instantly gears back up...won't stay in first.Just bought it used.....any ideas?
  • 46 Answers
Your shifter is likely loose. Try tightening it.
Posted on Sep 08, 2009
How to shift gears on a seven speed schwinn bike?
Always shift while pedaling. Start slowly, its not a race. Pull shift lever up, notice the change, then down. Keep working with it until your have a good confidence
Apr 27, 2014 | Schwinn Cycling
Losing power going up hills
sounds pretty normal. what speed do you try out the passing gear? anything above 35-45 mph and it will feel like neutral. Passing gear is actually only 1st gear. When you press down the pedal, it forces the transmisson to shift into low gear.
Dec 16, 2013 | Oldsmobile Alero Cars & Trucks
Car doesn't kick down gear going up hills
A/T
The modern A/T has 4shift methods.
Foot (passing) called detent TV kick down cable.
the shift lever.
the Vacuum modulator (load, = hills)
and tail shaft RPM (speed)
so seems like the MOD on the A/T is bad.
Apr 06, 2013 | 1992 Geo Storm
1972 schwinn breeze 3 speed......was working well. Now first gear slips while I'm riding. Once in a while second slips.
re-grease everything, clean it all up, check all your cables and shifting mechanisms, see if that helps
Jun 26, 2012 | Schwinn Cycling
Schwin Coronado,what is the procedure for shifting the gears
Enter "procedure for shifting the gears" into any search engne for instant video instruction. Or look on the Schwinn site for their version of a manual.
http://www.schwinnbikes.com/support/owners-manuals
Standard search engines produce instant answers to well-crafted questions.
Aug 05, 2011 | Schwinn Cycling
I have a 2000 chevy silverado and when in Drive going up a hill it seems like the transmission can't down shift or doesn't know what to do, I step on the gas and the rpm's don't go up and...
TRANSMISSION SLIPPING NOT ENOUGH FLUID IN TRANSMISSION OR NEED A TRANSMISSION FLUID FILTER CHANGE.IF YOU HAVE PROBLEM WITH OVER DRIVE.CHECK ENGINE LIGHT WILL FLASH ON WARN YOU PROBLEMS WITH TORQUE CONVERTER OR 3 - 4 SHIFT VALVES SOLENOIDS.
Jun 05, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Schwinn Sidwinder gears need adjusting. The one with 3 gears doesn't stay where I try to set it.
Keeping a derailleur in a given gear is the shifter's job. If the shift lever/mechanism doesn't click and stay where you place it, something is wrong internally. It will need to be replaced if, for example, a SRAM MRX grip slid away and let the guts fall out.
Whatever your particular dilemma, look for a friendly local bicycle shop to see what they can do for you. I replaced the entire MRX shifter set for a friend using an upgraded and better designed Shimano setup for under $25 and my own labor. But then, I'm an old hand at working on bikes.
For DIY:
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/shift-levers-shifters
May 10, 2011 | Cycling
I have a 1999 jeep cherokee that has intermitant transmission problems 1)shifting up it wind out to 2k-3k before shifting 2) at higher speed it feels as if it slips out of overdrive rpm increase but speed...
It will shift out of overdrive upon increasing throttle , pulling hills and so on. Your overdrive probably kicks in around 35 to 45mph and kicks back out as you increase throttle. Electrically controled speed sensor to control the response. Overwise the engine would bog down to a stall. Over drive is just that. It changes the gearing ratio to over drive meaning less then final gear 4 to 1 down to 4 to 3 etc more direct drive ratio to lessen consumtion of fuel with less stress on engine. Have shift speed sensor adjusted. Don't drive in overdrive in city if most driving is under 45mph
Mar 09, 2010 | 1999 Jeep Cherokee
Cycling Logo
88 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
