Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
There is a dial behide the top plate where cooling switchs are what is it, and my freezer is working but not my fridge
    Sergeant:
    Champion:
  • 255 Answers
Could be for flapper that lets air into fridge.
check that fan in freezer is working , replace defrost timer
Posted on Sep 08, 2009
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My g.e. 2 door no frost refrigerator are not cooling well but my freezer are ok.
open ur freezer and can u tell if it's blowing cold air or it just cold air,because if i'm right there's a fan back there in the freezer,
behide the vent, and if this fan has gone out,your freezer will be cool but ur fridge won't be
Mar 31, 2011 | GE Refrigerators
Fridge wont cool.
Refrigerators draw air from the freezer to cool them. There are several possibilities. First check to see if you need to defrost the freezer, this can cause a blockage stopping the air to the refrigerator also make sure that there is nothing blocking the air flow in the refrigerator.
You can set the freezer colder and turn up the refrigerator setting dial.
If these don't work it could be the fan that is supposed to circulate the air to the refrigerator is not working. The door switch for the light often turns the fan off while the refrigerator door is open.
If the freezer is all the way up and items in the freezer aren't frozen hard then you most likely need you system recharged or there may be something wrong with the compressor.
Jun 06, 2010 | Kenmore 64823 Top Freezer Refrigerator
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
Oct 08, 2008 | Refrigerators
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Smilar problem, but the model is GTH15BBMFLWW
Jul 16, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
