Tonearm skips imediately to center of album
Tonearm moves immediately to end (center) of album, instead of dropping at start and playing. It started moving part way in first (skipping the first track or so), but now it skips the whole thing.
    President:
  • 2,976 Answers
Your needle (stylus) is either worn out or not seated properly. If you continue to try using it without the problem being corrected, it will ruin your records. You can check it to see if it's worn out by dragging your finger over it, lightly, from back to front only. It should feel like a small pin. It should also be seated into the groove on the tonearm. If this doesn't correct the problem, replace it.
Posted on Sep 08, 2009
    President:
  • 1,564 Answers
Your stylus is damaged or worn. Or some one may have spun the balancing weight at the rear of the tonearm. Reset the weight so that it will drop when two postage stamps are lain upon the stylus end of the arm.
Marantz 530 skips after playing only 30 seconds the tone arm won't progress. It consistently stops (skips) regardless of whatever album at the same place
Make sure that the wires leading from the tone arm are not binding. And you might also want to check for bearing friction in the tone arm. Under light stylus pressure conditions, low friction is mandatory.
Mar 22, 2015 | Marantz Audio Players & Recorders
I have a technic sl 1200 mk2 , my anti skate is
I gather you don't know how to adjust the tonearm. First put the stylus pressure, and antiskating to zero. Balance the tonearm for a free floating position. Ortofon cartridges will list the stylus pressure, generally 1.5 grams. Dial in the correct pressure, and set the antiskating to the same as the stylus pressure. If you require more assistance, or would like to inquire about repairing your Technics, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 09, 2014 | Audio Players & Recorders
Arm not working. Stop/start light flashes red instead of staying solid
Don't try and force anything that won't move. Try this. With the power unplugged, place the tonearm over the record, if it will move freely, while rotating the platter by hand. Move the tonearm slowly over the surface of the platter until the end. Continue turning the platter by hand and see if the tonearm picks up and returns to the rest. See if that fixes your issue. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 09, 2013 | Technics Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Turntable stops before the end of a 45. Works fine for Albums. I found 1 solution but that says to take the player apart.
Just had this occur to me and after a couple seconds figured it out. Tonearm returns once it hits a certain height on the tonearm guide (the bit that goes up and down when you raise or lower the tonearm cue lever.) If you manually hold down the guide, the tonearm will continue to play the 7" until the end. You don't have to push down hard, just a nice gentle [pressure while the record plays should do it. It solved the problem for me.
Apr 23, 2011 | Crosley 0187SST Turntable
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
Tonearm goes to record and returns to start position without ever playing the record
Do you have an adjustable piece at the end nearest the pivot point [the bit that goes into the turntable] if you do then adjust the weight so there is more downward pressure on the record [ or just try putting weight on the tonearm ] and see if this helps
May 23, 2009 | RCA Audio Players & Recorders
Technics SL 1600 MK2
Your tonearm is damaged. More than likely the bearings on the tonearm have been damaged. Unfortunately, there is no easy fix for this. You'll have to have the tonearm replaced, however, parts for the SL1600MK2 have been discontinued. The tonearm for the SL1200MK2 might fit it, but you will need to do some retro-fitting in order to make it work properly. Something only a qualified service center could perform.
Hope this helps some.
DIGITAL ANALOG THERAPY
May 29, 2008 | Technics SL-1200MK2 Turntable
Tone arm travel
Tonearm is misaligned. This usually happens when you've moved the unit, or something has fallen on the tonearm, causing it's bearing to be misaligned. This is not an easy fix, and you will more than likely have to take it to a service center to have it repaired and looked at. Good luck!
Sep 08, 2007 | Aiwa PX-E860 Turntable
215 people viewed this question
 Grubhead
Grubhead
