Question about Frigidaire GLTF2940ES Front Load Washer
Horrible odor from Frigidaire Affinity ATF6700FS
My front load washer is about one year old and has begun having the odor problems I've read about. It is a musty, rotten egg smell which makes everyone gag and is smelling up the house. There is no apparent mold, I have done everything possible such as wiping the rubber gasket, keeping the door open, using Afresh, using small amounts of HE detergent, etc. The smell is so bad that I HAVE to close the washer door, but then the odor seems to be coming from behind the machine! We took the detergent drawer out (it was not easy), but there was no mold in there. I am beginning to think the problem is deep in the machine. Fortunately, my clothes and towels haven't begun to smell. Tomorrow I am going to call Frigidaire since I have a 5 year warranty and now realize that thousands of people have the same problem. Does anybody know if there has been a class action suit concerning this? I feel this could be a health problem besides a waste of time, energy, and money!
  • gillville482 May 11, 2010
    The smell is probably from mold inside the tub and behind the basket. You can not get to it without splitting the tub and removing the basket. If bleach and affresh don't help, it may have been introduced in the water supply. The appliance did not cause the issue so Frigidaire will not assume any responsibility.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%&
Posted on Sep 28, 2010
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Pause button stuck
I have checked with local supplier and found out that the part number for Affinity atf6700fs1control board is 137006030, since I can not return it, could anyone confirm it for me? Thanks!
Nov 12, 2013 | Frigidaire ATF6700FS Front Load Washer
How do I remove the filter on my front loading Affinity LTF6700FS0 to clean it?
Look at this video. The filter is in the black boot the runs from the tub to the pump.
Dec 05, 2012 | Frigidaire ATF6700FS Front Load Washer
Drain is plugged on Frigidaire washer ATF6700FS2
vacuum at full power from both sides, this should pull the rags further apart, making it easier for the water to flush them.
Nov 15, 2011 | Frigidaire ATF6700FS Front Load Washer
Frigidaire affinity ATF6700FS won't spin or drain water out
Some error code there? This may sound strange but give it a try. Unplug the electric. Leave unplugged 2 or 3 minutes, then plug it back in. This allows the controls to reset. It worked alot cases.
Inicially I could think in some drain problem, check hose for any clogged or obstruction there, try to jump voltage to the pumo to confirm if this device is working. If this dont solve it, you will need to check timer; in this link could finr some tip test: applianceaid.com/direct.html#burnt_timer
Visit this site to identify some parts replacement that you could need: partsearch/model.aspx?model_id=5152465&diagram (sample)
If you are not sure about how do it this job, or your machine is even under warranty, call the technician service.
Hope this helps.
Jun 28, 2011 | Frigidaire ATF6700FS Front Load Washer
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
609 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
