I need to know the dip switch positions to install a pentium III 866 mhz processor on an asus p3v4x motherboard.
    President:
  • 2,600 Answers
Below is the link to the user manual for that motherboard. Copt and paste the link to your browsers address bar. Make sure to make a copy for yourself for future refernce. Look at pages 14-19, that deals with the Dip switches. I did not however see a position for anything over 700 mhz. Good Luck ParrotHead PC Repair
http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
Posted on Sep 08, 2009
    Sniper:
  • 58 Answers
Refer page 18-19
JumperFree mode must be disabled when adjusing settings manually
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
Sep 26, 2010 | ASUS Intel 810E Chipset CUWE-RM...
Motherboard p3v4x : during bootup i get a system
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here: http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
or try the ASUS website and look under support or the discussion forums.
This will help: http://support.asus.com/cpusupport/cpusupport.aspx
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
http://processorfinder.intel.com/details.aspx?sSpec=SL52P
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info: http://www.intel.com/p/en_US/support?iid=hdr-AP+support
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=483&SearchKey=
Also Try this: http://processorfinder.intel.com/Default.aspx
Cheers,
Steve (Melbourne, Australia)
May 09, 2010 | ASUS Computers & Internet
Need bios
what is your motherboard name,and manufacturer ,go to official site and download it...
Apr 01, 2010 | NEC Pentium III , 866 MHz Processor...
Not so much a problem but I have an old Dell dimension with an 866 inteleron processor. I have 2 slots for Ram, each with 256 mb totalling 512, my question is can I replace them with 2 512's for 1plus gb...
Yes you can install 2 512 mb RAM for 1Gb in motherboard.But make sure both 512 RAM are same in configuration and frequency it is better you purchase both ram of same company.Then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 23, 2009 | NEC Pentium III , 866 MHz Processor...
Intel Pentium II Processor Upgrade
No, this highest the P-II went to was either 400 or 450 Mhz. Upgrading a thinkpad CPU may be difficult. Considering prices on used laptops now, I wouldn't think it would be worthwhile, either.
Neil
Feb 09, 2009 | Intel Pentium III , 866 MHz...
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Asus P3V4X/S370-133/Tualatin 1.2Ghz
It turns out that while the BIOS will not appear to recognize the Pentium 3 1.4GHz Tualatin CPU (SL6BY) in my Asus P3V4X motherboard, Windows XP does! I apologize for my delay in posting this.
I have five extra SL6BY processors that I'd like to sell if anyone is interested. I need to make some money to upgrade the memory in this antique to 2GB (turns out that low density 512MB RAM does work in the P3V4X, by the way).
Thanks,
Eric
Nov 22, 2007 | ASUS (S370L) Processor Board
Need help to set-up fcpga processe on asus P3V4X with asus-S370-L
Hi Neel, Are you running the board in JumperFree Mode? If so you shouldn't have to change any jumpers or dip switches. And the S370-L adapter card should NOT have to be set either, it should auto detect both processor core and voltage. If you don't know how to set the board up in JumperFree Mode let me know I'll walk you through it. If you ARE running in JF Mode then I'd contact Asus support. http://support.asus.com/ You have the right BIOS update to be able to support that proc but Asus had some issues with Intel chipset support with certain versions of the 370 adapter cards. (issues with both the S370-DL and the S370-L if I remember right) Let me know what happens, Dude
Nov 25, 2006 | ASUS (S370L) Processor Board
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
