WONT SPIN I HAVE A WASHINGMACHINE LG WM2032HW WONT SPIN TO THE RIGHT OR LEFT. WHEN IT DESIDE TO IT SOUND RUFF AND IT WILL ONLY SPIN ONCE OR TWICE THIN STOP.
  • 135 Answers
The motor usually dosen't fail but the control may have or the connection to the Hall sensor on the motor may have.
Posted on Sep 08, 2009
    Sergeant:
    Champion:
  • 255 Answers
Bad motor or bad belt going to motor
My 1998 4x4 expedition has a ruff take off from a dead stop when turning
Take a look at the stabilizer bar link, weak springs or suspension components, defective shock absorbers. That should get you the somewhere to start.
Dec 21, 2013 | Rockport Works Urban Expedition Boot Boots...
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
My immobiliser wont let me start the bike
This may help you ... http://www.youtube.com/watch?v=RTy_JKI9cQ0 ... probably not.
Resetting your security system depends on which system you have. To do any of them, you must have the fob. If you don't have the fob, only Harley can clear. Be prepared to prove ownership when you arrive.
To reset the code with a TSSM equipped bike, you will:
1) Set your kill switch to off
2) Quickly turn the ignition switch on, off, on, off, on
3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
4) Press and let go of your fob button twice (press fairly hard, it's designed to resist being pressed by keys and what not in your pocket)
5) Current PIN number will be displayed on odometer
6) Change the PIN by pressing the left signal until the desired number is reached
7) Press the fob button twice to cycle to the next number and repeat step 7
8) Press and let go the right signal and turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 2 through 4 must be completed in quick succession of each other.
Now you can have the bike armed, and disarm with the PIN (example PIN will be 25522 in the following steps):
1) Ignition switch to Accessories
2) Immediately press both turn signals at the same time (red key light on you speedometer will flash rapidly if done right)
3) Press and let go the left signal 2 times
4) Press and let go the right signal once
5) Press and let go the left signal 5 times
6) Press and let go the right signal once
7) Repeat for each of the last three numbers of the PIN (left 5 times, right once, left 2 times, right once, left 2 times, right once)
8) Red key on speedo will stop blinking if done right (security has been disarmed)
NOTE: Steps 2 through 7 must be completed in quick succession of each other.
To reset the code with a HFSM equipped bike, you will:
1) Have your key fob near the bike
2) Set your kill switch to off
3) Quickly turn the ignition switch on, off, on, off, on
4) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
5) Press and let go the right signal once
6) Current PIN number will be displayed on odometer
7) Change the PIN by pressing the left signal until the desired number is reached
8) Press the right signal to cycle to the next number and repeat step 7
9) Turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 3 through 5 must be completed in quick succession of each other.
1) Ignition switch to on
Feb 24, 2013 | 2010 Harley Davidson FXDF Fat Bob
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
LG WM2032HW Washer
You may have a bearing problem and it will need to be looked at by a qualified LG technician.  That is a big job and will require total disassembly of the tub and drum assembly to get to the bearings.  There are 2 of them.
May 06, 2008 | LG WM-2277HW Front Load Washer
LG WM2032HW spin cycle
I had the same problem. You most likely have a drain pump issue. For me, after getting to the drain pump, I found that the hoses leading into it were clogged with dirt. I cleaned all the hoses, and took off the drain pump itself. The impeller (the little plastic blades inside) had come off the pump shaft. I was able to clean out the impeller and pump housing and it went back on. You'll know it's all the way on because it will click into place and then it won't easilty (if at all) pull back off. After this cleaning, mine worked fine. Hope this helps.
Apr 02, 2008 | Washing Machines
Lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Jan 28, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
