Question about JVC RX-8010V Receiver
No sound output at all
I have a Jvc RX-8010vbk that I leave on all the time, (so that my kids don't have to fool around with the settings). Today I rearranged my living room and had to turn it off and un-plug it. When I plugged it back in and turned it on, there is no sound at all. I'm not getting any "overload" messages or it just turning off by itself or anything. Everything is turning on and staying on. I've checked all of my connections and settings and tried to just connect headphones to rule out a speaker problem, but no luck. Is there a reset or something that may need to be cleaned or checked internaly? I really love this receiver and use it for everything. Any help would be appreciated. Thanks!
  • mason03 Sep 09, 2009
    I've looked inside, I can only see 3 seperate little glass fuses, they're all O.K.
    Sergeant:
    Champion:
  • 255 Answers
Check your A-B speaker button. some have a small fuse inside.
Posted on Sep 08, 2009
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
Why no sound?
no mention of cables used . Could be analogue cables in ps4 on analogue output . Digital output would have a digital output port using digital cabling I would deduct on ps4..
May 20, 2015 | JVC Audio Players & Recorders
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
I am trying to hook up a RX-B503 amplifier to my KAWASAKI receiver. I have taken the output of the KAWASAKI to the input of the RX-B503 but I'm not getting any sound. I have talked to tech pro and they...
You're already playing around with it and trying to blow it up. Amps/receivers never feed back into other electronics in a continuous loop back to themselves. What 'output' were you trying to run to the the unspecified Kawasaki? Speaker, Tape Out or Pre-Out?
The RX-B503 is a receiver, so it has its own sources.
You don't say what you're trying to accomplish with the Kawasaki. Is it to drive more speakers, slaved to the TechPro, which is stereo-only by the way?
Use the Preamp OUT on the TP for volume-controlled STEREO programming to anything downstream.
Do you even have manuals for any of this?
Jul 13, 2011 | Audio Players & Recorders
Jvc rx 703b repair--I was playing on a technic sl mk2 turntable made a loud noise then went out on one speaker then later the other
Hello
Your Amps' output section has shorted. Don't connect any other speaker to it, till it has been repaired. It will burn out it too. In some sets this section will be of transistors, and in others, an IC will be used. Anyway it has shorted and has to be replaced. OK.
Apr 19, 2011 | JVC Audio Players & Recorders
Trying to connect my computers sound card to amp via spdif to optical in amp not working why?
The JVC audio piece of this is straightforward if your PC's soundcard is configured correctly to output the right digital bitstream. You most likely have some proprietary software managing the Sound Card and its properties. Find it and look around for something that controlls the spdif output. Usually there's a way to change the sampling-rate.
Your receiver will surely accept 44.1 khz, maybe higher for certain sources like mulitchannel DVD video. Experiment with different PC settings and play something to test it. Eventually you'll figure it out.
Of course, optical cables also need to be routed carefully to avoid small-radius bends which will cause data or signal loss.
Feb 03, 2011 | JVC RX-7032V 6.1 Channels Receiver
No subwoofer output
yes, you do have to set up the sub output in the reciever.
May 17, 2008 | JVC RX-8020V Receiver
JVC RX 6042
just google jvc go to customer service at the bottom look up manuals and u can print it right off the internet no cost
Apr 02, 2008 | JVC RX-6042 Receiver
JVC RX-702B only detects linear PCM, not multi-channel digital
Like most receivers it will probably have settings for the sound output. Once you find this it will be just a matter of switching the system over to Dolby signals. If you find that it already set like that, try switching the DVD or blue ray player you are using or whatever source, using their sound settings on them. So that both devices are sending and detecting Dolby signals.
If both devices are set correctly then there probably will be a fault in the decoder of the JVC.
Dec 07, 2017 | JVC Audio Players & Recorders
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
JVC RX-8010V Receiver Logo
393 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
