Question about Motorola Mobility HS810 Consumer Headset
Pairing my headset with my new Motorola phone
I have just purchased a new Motorola V8 and wish to pair my HS810 headset with it, can you please help me with step by step instructions.
This works!
Posted on Jul 09, 2008
    Problem Solver:
  • 9 Answers
I'm not good in english but i'll try. i used h-700 which i think they are same, you have to close your boom(BT) first and and hold the call button for few secs then open the boom while the light is show(still push the button) then release the button then you open your phone and open bluetooth menu choose search for device, your bluetooth should appear on the list.
Posted on Jan 07, 2008
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
Hi, how can I pair up my Motorola Bluetooth HS810 with my iphone?
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 30, 2010 | Motorola Mobility HS810 Consumer Headset
I just purchased a Motorola H780 Bluetooth Headset and I am in discovery mode and it does not find my device. Can you help me? I charged my device and my phone is a new Samsung phone.
When your heaset is in pairing (discovery) mode (its indicator light is steadily lit, whilst in this mode), make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
Dec 07, 2010 | Motorola Mobility H780 Bluetooth Headset
Pairing motorola hs810 with sony ericsson k800i
unless it is a stereo bt haeadset is the only way you would hear a mp3......
Aug 18, 2008 | Sony Ericsson K800i Cellular Phone
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Cannot pair hs810 with my razor v3
here the steps, first you have to open your BT to pairing mode by close your boom and hold the button untill the indicator light show(not flashing), when u see the light DO NOT release the button, open your boom the you can release the button after that open your phone bluetooth then choose search for device there should be your BT(HS810) on the list then pair it.
Dec 27, 2007 | Motorola Mobility HS810 Consumer Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility HS810 Consumer Headset Logo
41 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
