Question about Dryers
Gas valve will not open - Dryers
    President:
  • 1,714 Answers
Is the ignitor glowing? If not, change the ignitor, if yes, change the gas valve coil.
Posted on Sep 08, 2009
Any ideas as to why gas valve wont open
Usually that the thermocouple is worn out. It is a small metal tube that sits in the flame and tells the gas valve that the pilot is alight and hot and the valve can be opened. Call in a gas technician.
Nov 19, 2015 | Kenmore 24 in. Gas Self-Clean Single Wall...
1F ERROR CODE appears on Hayward model # h250PED2
Code Fault Diagnosis Step Remedy
None
Open FC3 and/or
F1 Fuses
1. Check for faulty Gas
Valve wiring.
Inspect Gas Valve wiring. Ensure insulation on wiring is not worn. If
OK, proceed to step 2.
2. Verify that Gas Valve is
not defective.
Mesure for resistance across Gas Valve terminals and between each
terminal and ground. If short exists, replace Gas Valve. If OK, proceed
to step 3.
3. Check for faulty Control
Module wiring.
Inspect Control Module wiring. Ensure insulation on wiring is not worn.
If OK proceed to step 4.
4. Control Module is
defective.
Replace Control Module.
Ignition Failure 1. Ensure gas supply shutoff
valves are open.
Ensure that main gas shutoff installed adjacent to heater is open. Ensure
that knob on gas valve inside unit is in ''on'' position. If OK, proceed to
step 2.
2. Check for low gas supply
pressure
Ensure inlet gas supply pressure is between the minimum and maximum
values indicated on rating plate. If OK, proceed to step 3.
3. Check for faulty flame
sense wiring or connection.
Inspect flame sense wiring. Ensure wire harness terminals are securely
fastened to flame sense and to control module. If OK, proceed to step 4.
4. Check for faulty gas valve
Inspect gas valve wiring. Ensure wire harness terminals are securely
fastened to spade terminals on gas valve. If OK, proceed to step 5.
5. Check for gas valve
failure or gas valve relay
failure.
1. Measure voltage across gas valve during trial for igintion. If 24VAC
is present and gas valve does not open, gas valve is defective. Replace
gas valve.
2. If 24VAC is not present, gas valve relay on control module is
defective. Replace control module.
6. Check for blockages in
gas orifices and burners
Inspect gas orifices for blockages which could prevent gas flow. Remove
and inspect burners for blockage
Jan 02, 2015 | Hayward H Series Electronic Ignition...
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
Does this valve have a standing pilot? if not, if my hot surface ignitor lights up and the furnace fails to light would you consider it to be a faulty gas valve? I am getting a constant 24 volts fro
If your getting 24 Volts to the gas Valve and the gas Valve is not opening replace your gas valve If your not getting a full 24 volts check your Transformer and the ground to the gas valve.If the gas valve still does not open change the Gas valve.
Nov 18, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
I have a bryant gas furnace M#:395cav036055acja. I can hear the gas valve open but theres no gas flow. I can also see the ignitor light and then cycle off after several restarts. Do i need a new gas valve...
The first thing I would do is to shut valve off on gas supply line and remove fitting and nipple that screws directly into the gas valve. There should be a fine mesh screen in the gas inlet. Make sure it is clean and not obstructing gas flow. Use teflon tape and/or pipe joint compound on all threaded fittings when you reassemble. When you have everything tight except the union you can slightly open gas valve to make sure you have gas to that point.After you finish tightening all fitting turn gas valve back on and check for leaks.
You can put a few drops of dish soap on each threaded fitting to check for leaks. If soap bubbles then you have a leak. Repair leak and see if furnace will fire. If you are sure you have gas to gas valve and you can hear valve trying to open but still no flame I would replace gas valve.
Good luck and I hope this helps you some. Thank you
Dec 19, 2010 | Heating & Cooling
Main gas valve will not open . already replaced starter
have you replaced the primary and secondary gas valve coils located on the gas valve body,they get weak and cant hold the gas valve open
Feb 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas Dryer
There is a flame sensor that senses when the ignitor is hot enough to light the gas. If the flame sensor is bad the gas valve won't open. It also might be the valve itself. There are 2 coils that must open for the gas to get through the valve. If one of the coils is bad the valve won't open.
Jul 21, 2008 | Frigidaire FGR231A Gas Dryer
Dryers Logo
Top Dryers Experts
