Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Picture Quality I have tried to adjust the picture with color, hue, sharpness, etc. What should i have the settings on to get the best picture out of my 57" rear projection tv
  • 60 Answers
Clean the lenses and mirror. - Carefully with no liquid, just a micro-fiber cloth. They can be accessed by removing the front screen.
There are items in the service menu that can tweak color drive and grey scale, but you can really mess up a TV if you do not know exactly what you are doing. You can also do a comprehensive convergence in the service menu.
Posted on Sep 09, 2009
Convection starts ok, but quits after 10 minutes. It's 11 years old
Trying to calibrate mu sharp 32LE700UN. Settings are as follows:'
OPC is off, baklight at +14, contrast +30, brightness +2, color +2, Tone 0, sharpness 0, CMS Hue +12. Are there any settings I am missing or need to change to get the best picture? Also, color temp at middle and AV Mode at Standard.
Dec 16, 2009 | Sharp R-930AK Convection/Microwave Oven
Color issue
download this manual
http://merchant.satisfusion.com/sf/library/manuals/owners/50V720.pdf
see page 59,60,61,62. The problem can be the lamp
After extended use, if the TV picture turns dark, the color looks unusual or LAMP INDICATOR light turns on, then it
is time to replace the lamp with a new lamp.
Mar 21, 2008 | Hitachi 50V720 Television
The picture quality of the camera is very bad on my mac. im trying to use skype. first i thought it was the lighting in the room but it has been like that since i bought it. how can i get a better picture...
Run the program to use this webcam. In that you would be able to set up various items like color, hue, contrast etc etc. tweak all of them and set the best possible picture. Also rotate the ring around the lens. Both clockwise and anticlockwise to focus on to you to get the clearest picture.
Nov 21, 2009 | Macally IceCam Personal Web Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
Green hue on all inputs
Most likely there is a failure in the video processing. The flickering was from the failing components breaking down.
Your set can be serviced by an experienced tech who has spare boards and the facilities to service your set.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Poor color and claradie
You may have picture tube problem that is and old set if you can send me a picture of the tv working I' will analyze and let you know if is worht to expend money on this e-mail me networks@msn.com
Apr 04, 2008 | Sony KP-53HS30 53" Rear Projection...
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Can't adjust properly
Steve I can Help you with this Contact me on Live Chat ttech
Jul 21, 2007 | Akai LCT3201AD 32 in. LCD Television
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
