Question about Frigidaire Dishwashers
Washing cycle has been running for an hour and a half, soap has not dissolved
  • 135 Answers
You are not getting enough water or the pump is not working.
Posted on Sep 08, 2009
Detergent is still full after 5 washings. I ran it through several cycles and purchased powder to run it and it still will not work
What? The soap lid won't open, or the soap won't dissolve? If the lid is opening, but the soap won't dissolve, then you're not getting proper water flow. Check your wash arms for clogged holes. The other thing to check is the sump area for a clogged food trap or clogged or broken chopper. You might be able to find a video on YouTube that shows you how to do this, otherwise, you should call a professional dishwasher repairman.
Sep 25, 2014 | Kenmore Dishwashers
Soap leaves behind after wash cycle
Could be using too much soap, soap that's too old will clump and not dissolve completely. If your soap is clumpy and very dry, dissolve it completely with boiling water in a pan, then put it in the unit.
Jun 15, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Bosch Diswasher SHE68T52UC
Error code 08 says it's a temperature sensor problem. If the temp sensor is bad, the water heater may not be getting the water up to a hot enough temperature to dissolve the soap block. Also, while you have the unit out for repair, make sure that the drain hose is clear of debris. I have seen a number of dishwashers lately that were replaced simply because they "weren't cleaning" or "draining slowly" where the only problem was a blocked drain hose.
Feb 21, 2014 | Dishwashers
The soap doesn't dissolve
your using to much soap . pour vinegar about a half cup into the bottom of the washer before you start, do this about 3 washes then should be okay,
Sep 09, 2012 | Magic Chef 5-Cycle Dishwasher
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
Dish soap is not dissolving
First try a different brand of soap. Check that the soap door has opened about half way through the wash cycle. You may need a water softener.
May 13, 2010 | Maytag 24 in. MD5600 Jetclean II Built-in...
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Apr 05, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
