Question about Linksys Wireless-G WRT54G Router
I have a Linksys Wireless G WRT54G Router version 5 and I lost my setup disk and cannot access the internal web based setup and Iv done everything Iv read to do and now its not even showing up as a connected device. Is there any other way to access it?
  • Hollie Howard Sep 08, 2009
    I cannot get to the web based utility browser-its not communicating with it. Iv went step by step thru Linksys downloads and troubleshooting and this is one of the things I did and did not work. Any other ideas?
  • Hollie Howard Sep 12, 2009
    Hi u gave me some instructions about running a ping test to try and get my Linksys Router WRT54G version 5 back up and running after losing the setup disk and no downloads from Linksys for this version-I did get the 4 responses after the ping test and I did the whole reset and the ping test showed it was communicating but no luck with the setup page- what could be the problem now?
  • 61 Answers
Hi there. No need to run the setup CD. Check the IP address first to see if the computer is communicating with the router. Go to command prompt (if XP, simply click start then go to run and type in CMD and hit ok. A black screen will pop up. Type in IPCONFIG then enter. Check the IP address and default gateway (by default, the router's IP is 192.168.1.1 which will show as the default gateway). Launch internet explorer and type in the default gateway on the address bar. (No www). If you cant pull out the page. Go back to the black screen (START>RUN>CMD) and type in ping (default gateway) ex. ping 192.168.1.1 there is a space between ping and the default gateway. If you got 4 replies you should be able to access the router's page if not, reset the router by pressing and holding the reset button of the router (usually it is the red hole at the back of the router along with the ethernet ports) for 30 seconds. After 30 sec, power off the router (unplug at the back)never release the reset button and wait another 30 sec then plug the power back in and wait another 30 sec before releasing the reset button. You should be able to access the page then. Go back to the black screen (START>RUN>CMD) then do again a ping test. type in again ping and then the default gateway. (ex. ping 192.168.1.1). You should be able to access the setup page now.
Posted on Sep 08, 2009
Testimonial: "Thanks for the help and you have taken me so much closer to getting this running again then anyone. HH"
  • 395 Answers
Reset it from the back and cnnect a LAN cable to any of port 1- port 4. On your explorer page go to the address bar and type this 192..168.1.1click enter and this would do the trick.
Cheers
Lost password for wireless devise, cant log onto the
A forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Follow this blog to reset your password in linksys router-reset linksys router password
If you need any kind of technical assistance then you can contact support cell at http://vtechsquad.com/linksys-router-support/
Sep 05, 2012 | Linksys Wireless-G WRT54G Router
Cant connect to internet
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
I lost the security key to my wireless internet how could i disable my security
This article will guide you on how to change the password of your Linksys router.
NOTE: The default password of your router is "admin" and no User name. It is recommended to change the Password for security purposes. If you forgot your Password, press and hold the reset button at the back your router. To learn how to reset the Password of your router, click here.
Changing the Router's Password
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click on the Administration tab.
Step 3:
Enter the new password in the Password field and Re-enter to confirm.
NOTE
: If the window on your router's web-based setup page looks different, click here.
Step 4:
Click 3695-017.png.
NOTE: The next time you log in to the router's web-based setup page, make sure to enter the new password.
Related Articles:
Setting-Up WEP, WPA or WPA2 Wireless Security on a Router
Checking the Wireless Settings on a Linksys Router
Downloading at Linksys by Cisco Support Site
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
I have forgoton my key words
If you forgot your password, we can actually access the router web ui.
Accessing the Router's Web-based Setup Page
Step 1: Open your web browser.
Step 2:Enter your router's IP address on the address bar and press the Enter key.
NOTE: The router's default IP address is http://192.168.1.1.
Step 3: The Enter Network Password window will then appear. Type your router's User name and Password. Click OK afterwards.
Web-based Setup Page Wireless Security Options
On the web-based setup page, you'll be able to see all of your router's wireless security features. Wireless settings wherein you can see your network name and once your click wireless security sub tab under wireless page you will then see your network key or password (passphrase).
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
I got new laptop and i want to conect with wireles but is asking for security key which i dont know where to check to find it. How can i do it/
NOTE: Before accessing the router’s web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router’s Web-Based Setup Page
Step 1:
Step 2:
Go to the Address bar and enter your router’s IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router’s password ("admin" is the default password), then click OK.
To setup or SEE the WPA Wireless Security on your Linksys router, follow the steps below:
Setting-Up the Wireless Router to Use WPA
Step 1:
Access the router’s web-based setup page. For instructions, see above
Step 2:
When the router’s web-based, setup page appears, click Wireless and select Wireless Security.
Step 3:
Select WPA Personal under the Security Mode drop-down menu.
NOTE: IF YOU ARE JUST CHECKING ON THE PASSWORD NO NEED TO GO ON JUST TAKE NOTE OF THE WPA SHARED KEY AND USE IT IN YOUR LAPTOP WHEN ASKED OF THE PASSKEY
Step 4:
Select TKIP on WPA Algorithms.
Step 5:
Enter your desired WPA Key on the WPA Shared Key field such as “MySecretKey.” This will serve as your network key whenever you connect to your wireless network.
NOTE: Do not give this key to anyone. This key will secure your wireless network. Leave Group Key Renewal to 3600 seconds
Step 6:
Click 3695-017.png.
If you need further assistance please do not hesitate to contact me....GOOD LUCK!!!
Oct 28, 2009 | Linksys Wireless-G WRT54G Router
With Linksys wrt54g v6 I cannot access the setup page - I get window that says management mode firmware upgrade
  If the Power LED on your Linksys router is blinking, this means the firmware is corrupted. Since the firmware is corrupted, you won’t be able to access the web-based set up page of the router. Instead, you will be using tftp.exe to update the firmware. We recommend that you perform the following procedure in a Windows-based computer.
Downloading the Firmware
Follow the procedure here:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3703&p_created=1151556377&p_sid=7FfWNnGj&p_accessibility=0&p_redirect=&p_lva=19073&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Mjc3OSwyNzc5JnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cmVzZXR0aW5nIHRoZSByb3V0ZXI*&p_li=&p_topview=1
Aug 26, 2009 | Linksys Wireless-G WRT54G Router
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
285 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
