Question about Frigidaire ATF6000ES Front Load Washer
Same problem; open up pump
I had the same problem and what I did was open the back panel and cleaned out the pump. sometimes my kids will "underload" the washer and I'm convinced this lets air inside the pump, resulting in the "sucking" of air. Once the pump is cleaned and the water is out of the tank the pump "primes" itself and works like new.
  • 135 Answers
If you are getting air in the pump you are using way too much soap. Over soaping will destroy the bearing in front loaders and that is a $600.00 repair.
Posted on Sep 08, 2009
Washing machine not taking in water
Check the inlet valve screens, in back. Clean them out. If you are inclined to checking the solenoid coil resistance, make sure they are not open or shorted out. Also, check the lid switch, sometimes the kid switch goes bad, do you hear it "click" when the lid is closed?
Nov 11, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Have a 90 Johnson 115 hp. will idle and stay running, but when you get it underload and full throttle it bogs out and wants to die, but it back in neutral and it will go back to an idle and run for ever......
There are three cylinders and three carbs, the carbs are linked by a small plastic clip on one of the linkage rods, image attached. One cylinder was running fine, 2 cylinders remained at idle. Under load it bogged down. I had the same problem on an Evinrude 70. I guess you have checked the plugs and gaps?
Dec 13, 2017 | Boating
Lg lcd tv humming sound which varies throughout a programme no rhymn or reason to it but especially noticeable when quiet part of programme
Alot of Tv's have this sound that comes from the speakers or the back of the set. Its normally when the transformers inside are underload they start buzzing. this could come from the Powersupply or the Inverter. When changing channels they change their tone sometimes.
Mar 22, 2011 | LG 32LG30 32 in. LCD HDTV
Water is leaking out washing machine door and now F-05 has come up on the machine. The number i got of the front of the machine is AQXXF149PI as am unable to open the door.
as too opening the door you would have to remove the lower panel and reach up on the inside right side and grab the pull cord that is attached to the door lock assembly as to the f05 error clean the pump clean out you have items stuck on the inside or as they say if you have kids special surprises lol if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Feb 08, 2011 | Hotpoint Washing Machines
Engine run ok but diesel pump scream from back of car and when driving car at 40 to 50 mpr and put foot down car very sluggish and dont kick down and go
Change the fuel filter first. The pump can get noisy if it is underload from the filter being plugged or from the fuel pump starting to fail. If it is still noisy it would be best to change the pump at some point before it fails.
Dec 11, 2010 | 2006 Jeep Grand Cherokee
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Open the handset to clean keypad
Hi Sue,
Sometimes there's a screw or 2 inside the battery compartment, other than that they snap together.
Once you get the keypad out, wash it in warm water with a couple drops of dish liquid, rinse and pat dry. The Pc Board the keypad sits on can be cleaned with alchohol and Q-Tip.
Hope that helps.
Geno
Apr 01, 2008 | Panasonic KX-TGA650B Headset Phone
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
