Question about GE Profile Spectra JBP95 Electric Kitchen Range
GE Spectra electric oven slow to heat
It seems to take forever for our oven to heat up. Heats up faster on convection than on bake, but is still quite slow (maybe 30 minutes to 400 or 450?). Sometimes it seems it just won't get there.
Only other oddity is a difference in temperature when the oven is on bake or convection - about right on on convection, and 25 degrees too cool on bake.
And from reading other responses, I don't seem to have any bottom element.
Model JBP95BF1BB
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
ginko
  • 19396 Answers
SOURCE: GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 04, 2009
SOURCE: Bosch HES255U Covection bake slow to get up to temp.
My Bosch HES255U Freestanding Electric Range has been reading an error code of all "E's" or r 2 E E. I shut it off completely through the circuit breaker and allow it to reset. When I turn it back on, it starts to beep and shuts off.
Posted on May 03, 2010
freetek
  • 5568 Answers
SOURCE: oven temperature is off - when set to 400 it heats
Possibly, but the sensors can be of a couple of different types and one type, a thermistor, isn't very accurate so there may be an adjustment for it.
Posted on Dec 01, 2010
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
I have a built-in GE electric convection-regular oven. Model JT915W0F8WW. I don't understand when I push the convection baking do I change the baking time? Isn't it suppose to bake faster than the...
As a genaral rule of thumb.. Most recipes can be adjusted for convection oven use by decreasing the temperature by 25 degrees F and decreasing cooking time about 25%. Dishes with cooking times over 45 minutes, and that might dry out too much (like lasagna, or meatloaf) you should cover for the first half of the cooking time, and then remove the cover.
Aug 31, 2008 | GE Kitchen Ranges
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JBP95 Electric Kitchen Range Logo
408 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
