Question about GE Refrigerators
Refrigerator is clicking and not restarting - GE Refrigerators
    Sergeant:
    Champion:
  • 255 Answers
Bad compressor relay or bad compressor, replace compressor relay first.
Posted on Sep 08, 2009
Clicking noise after power outage
If you had a clicking noise about once a minute for 3 to 5 times, then unit worked fine, you have no problem, it was just letting the pressure equalize in the system before the compressor could restart. (this happens if you had a very short power outage).
If you are getting many clicks and compressor is not starting, you will have to replace the motherboard.
May 27, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
My GE Hotpiont refrigerator is not running and its making a clicking niose and the fan moves each timr it clicks
sounds like a bad compressor.is the compressor hot,if so the clicking is probably the overload tripping out, you can unplug unit and brush out the condenser coil let the compressor cool and try to restart
Feb 04, 2010 | Refrigerators
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
The fridge part of my fridge freezer appears to have stopped working
Look to the freezer for your problem. Frost free refrigerators are cooled by air from the freezer compartment. If the freezer cooling coil freezes up air flow to the refrigerator is lost. Look for signs of frost on back wall of the freezer section.
Located the defrost timer, turn the clutch head screw clockwise SLOWLY until you hear one audible click. The system will then be in the defrost mode. During the 18-22 minutes of the defrost cycle heaters are energized and defrost should take place. If defrost happens and the timer does not restart into the cooling mode, rotate the screw one more time SLOWLY to the second click and the system will restart in the cooling mode. Replace the timer in this case.
If the timer restarts the cooling after the defrost period and defrost does not happen your problem is in the defrost heaters or defrost thermostat. They are located inside the back wall of the freezer on the cooling coil.
Jul 05, 2008 | Samsung Refrigerators
Kenmore side by side refrigerator not cooling
Check inside back wall of the freezer for frost buildup. It would be a sign that the defrost system is not working and the coil inside the back wall is frozen over stopping air circulation to the refrigerator.
Defrost system has a timer that energizes a heater and a defrost termination switch which shuts off the heaters when the coil is warm enough for all ice to be melted. If you have the frost, locate the defrost timer and turn the clutch head screw clockwise SLOWLY until you hear one audible click, the compressor will shut off and the system will be in defrost. After 18-22 minutes the refrigerator should restart automatically. If it does not restart after 25 Minutes turn the timer screw again to the second click. Refrigerator will then start. Replace the timer.
If it restarts after the 18-22 minutes and does not defrost ether the heater or defrost thermostat is bad.
Jun 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Compressor hums and shuts off
This sounds very much like a compressor failure. unplug the refrigerator and check the condenser for cleanliness. After cleaning the condenser and allowing the compressor to cool, plug it back in and listen for the same sounds. If the compressor was overheated it should restart after it cools. If it does not restart the compressor could be seized. Check the compressor warranty against the age of the refrigerator.
May 19, 2008 | Kenmore 72912 / 72914 / 72919 Bottom...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Don't start smooth
restarting of refridgerator may damage your compressor motor due to overload.
when you switch off the refridgerator the compressor is in load condition, sudden restart overload the motor, it consume more current so the light going to dim.
solution. If your refridgerator have no delay circuit inside,
use a refridgerator stabilizer or attach a delay circuit,
if you have the the restart delay circuit may problem repair it.
Jan 18, 2008 | Refrigerators
Start not smooth
sudden restart may damage your compressor motor
overload the motor make light dim
sol.
  1. check your line supply plug and line loose contact problem
  2. check your motor on off relay or circuit problem replace it
  3. line supply voltage variation prevent it
  4. use a refridgerator voltage stabilizer (with delayed restart circuit)
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
