I have replaced the ink with a new ik catridge the printer is showing that the ink is full but it starts to print well then fades and is unreadable is there a cleaning program or something
  • sakkal Sep 08, 2009
    hp designjet 130 how do i clean the printer
    this made no difference still very faint
  • 453 Answers
It would be great if I can have the model of the printer.
You can try to reinstall the ink cartridge and clean the printer head.
Posted on Sep 08, 2009
  • 2 more comments
  • Sai Kiran Camsarapalli Sep 08, 2009
    If a printhead fails or needs attention,
    Make sure the printhead is correctly seated. If this is not the problem, the most
    likely cause of failure is that the printhead contacts need to be cleaned. You will
    need the following cleaning materials:
    • Clean, soft, lint-free material that will not come apart or leave fibres when
    damp (a coffee filter, for example)
    • Distilled or filtered water
    • Paper towels
    Make sure the printer is powered on, then do the following:
    1. Open the front hinged flap at the right of the printer.
    2. Open the second (back) part of the flap and lift it back fully. The print
    carriage will move to the left and then back to the right. Wait for it to stop.
    When the carriage has stopped moving, unplug the power cable from the
    printer.
    3.Pull the printhead cover up and towards you, so that the hook at the front
    unlatches itself, and then push the whole cover back, so that the printheads
    are exposed.
    4.Remove the failed printhead by lifting the small handle at the top front and
    using it to pull the printhead vertically up and out of the printer.
    5.Ensure that no tape is covering the printhead contacts. If the tape is present,
    remove it.
    6. Gently wipe the printhead contacts with a clean, soft, lint-free cloth.
    7. If the printhead contacts are still dirty slightly moisten the cloth with distilled water and continue softly wiping
    the contacts until they are clean.
    8.Place the printhead on a paper towel, the nozzle plate facing up, and leave
    it to dry for at least five minutes.
    9. While the printhead is drying, clean the contacts inside the carriage in the
    same way.
    10.When both the printhead and the contacts inside the carriage are dry, reinsert
    the printhead by lowering it into place and return the small handle to
    its lower position. Press down firmly and evenly on both the front and the
    back of the printhead to make sure it is correctly seated.
    11.Pull the printhead cover towards you, ensuring that the hook at its front edge
    latches onto the tab, and then push it away from you to close the cover.
    12.Plug in the printer power cable.
    13.Close the rear part and then the front part of the outer flap.
    To use the software in the system you may want to try this
    Windows XP
    1. Click the Start button in the Windows task-bar.
    2. Select Settings and then Printers & Faxes.
    3. Right-click the icon that refers to your printer and select Printing Preferences.
    Windows 2000
    2. Select Settings and then Printers.
    Windows 98 and Windows ME
    3. Right-click the icon that refers to your printer and select Properties.
    You may also check the User manual for the cleaning process but even if these does not work then the problem is with the cartridge itself. You may have to return this cartridge and get another one.
    Okay now we can confirm the issue is with the cartridge itself. The cartridge you have received is faulty with the circuit in it. You can get it replaced by taking it to the store where you purchased it from.
My TX550W ran out of Black Ink (T103) and I replaced it with a Genuine Epson Cartridge compatible with my printer (73N), My computer status monitor/ink check on the printer shows the black ink is now full...
Sometimes the ink does take a while to come from the cartridge to the print head. Performing 1 head cleaning procedure may fix this. But only do this once, anything after is just wasting ink. Also make sure no part of the air tab sticker has blocked the air hole in the cartridge. Have a look at the new one you have to find the hole. Its just under the sticker you take off before installing it into the printer.
I hope this helps Regards GM
Apr 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
I have a Kodak Easy Share 5500 AiO Printer. I was
Bad new catridge not impossible, I would return the catridge to the store.
Sep 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer has been idle for several weeks.When I came to use it the printing is broken and faded looking.How do I clean the cartridges?
HP Deskjet 5550 Printer.
The deskjet printers should not be kept idle.
At least once in two or three days, you can take one page print out.
This has to be done, otherwise, the inks both Black and colour will get frozened and sometimes it will become dry at the catridge mouth.
Black Ink is 56 and Colour is 57.
Solution :
01. Manually remove both catridges from the printer carefully.
02. Shake the catridges with full force pointing towards ground. You can find out now, that ink is coming out from the catridges which was frozen or dried up.
03. Clean the cartridge drive with a nice cloth and cleaning liquid.
04. Re install both catridges and take a test print out.
05. Recommended to have a service contract with local HP Authroized printer vendor to have a regular maintenance at least once in a month.
Jul 21, 2009 | HP DeskJet 5550 InkJet Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
KEEPS SHOWING LOW INK/
you get from dell 922 all in one software 'replace catridge' option use that option
Feb 24, 2009 | Dell 922 All-In-One InkJet Printer
Text becomes unreadable after one page of printing
model of the printer ? sound like a
heating device problem.
Aug 10, 2008 | Dell A920 InkJet Printer
Printing light blue will full ink
its either the catridge head is bad or yr new ink isnt too good although its new it still can go bad. now try using menthylated spirit sucked in a tooth brush thats not too hard . use it to clean the inside of the cartridge head. that is those spots inside. cos atimes dirty could cause such problems. so try it out.
hope this helps
thanks
May 31, 2008 | HP PSC 1350 All-In-One Thermal Printer
12 people viewed this question
jasbo
jasbo
