Question about Maytag Neptune Washer
I have the maytag neptune mah8700aww and it won't spin at all. i can hear the motor running but the bucket doesn't turn.
    Brigadier General:
  • 5,158 Answers
The drive belt for the bucket has either come off or broken. when it is shut off try and turn the bucket by hand. it should turn very easily.
you will have to replace the belt or have it reinstalled
robert
Posted on Sep 08, 2009
My Maytag Neptune MAH8700AWW washer when in the spin dry mode shuts down with a suds error?
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
I machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Washing Machines
Maytag Neptune rotates but not in spin mode
see the causes:
t doesn't pump or spin
frozen puller or belt broken pump, lid switch defective
It pumps, but doesn't spin
lid switch defective+motor coupler defective+belt broken+clutch worn+drive motor faulty+transmision not shifting properly+basket worn.
It spins only with the lid closed
lid for security reason.
see the diagram
Jun 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE FRT LD WASHER MAH8700AWW,NOT COMPLETELY THE SPINNING/DRAINING CYCLE,LEAVING CLOTHES VERY WET,WE SELECT SPIN CYCLE ALONE FOR EST. 9 MIN., THEN DRY, NEED A FIX - HAVE ONE ?
Check that the pump is operating properly. hold the drain hose over a bucket during pump/spin make sure its a reasonable output from the pump..If not remove and clean your filter, then readdress problem as before, if still no cure then check the pump blades are free.....If all is well and pumping okay then spin should be fine providing the motor is okay......Good Luck.....
Feb 16, 2011 | Maytag Washing Machines
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune MAH8700AWW Does not always spin out all the water and shows error message ND (no drain)I have to run the spin cycle again at least 1 or 2 times. The fabric softener dispense quit working...
There are two motors inside the unit, one for turning the inner basket during wash and spinning, the other is a drain motor(smaller, found on base in back right area) It is turned on by the timer(or control board) to drain water. Suggest you first pull drain hose out slightly while running to see amount of water being discharged into stand pipe while draining. (it is possible to create a mess doing this, so have a towel or two ) Check you do not have a kinked drain hose also, easy fix but not likely. If not a full flow of water while draining you may have something lodged in drain pump or pump going out......you have to disassemble to look, need towels for sure. Be safe and always unplug.......
Usually problem is one of these two
good luck.
Mar 16, 2010 | Maytag Washing Machines
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
My Maytag Neptune washing machine won't spin in the spin cycle
it may be the carbon brushes on the motor worn down, may need to replace, ideally the black carbon brush needs to more than 10mm if less the brush are struggling to have contact with the armature of the motor
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
