Question about Whirlpool Washing Machines
Hi i have a whilpool 5132E top load washing machine i bought second hand, my cloths collect fluff, especially the towels. Does thi model have a filter.thank you chrissie
  • 415 Answers
No but it sound like the agitator has a sharp edge and chewing up the cloths feel your finger all the surface area of the plastic and feel for a gouge or rough area then get sandpaper or other type of item that will smooth it out and that should stop the fluff issue
Posted on Sep 08, 2009
Model 3LSC8255EQ. TYPE111. When my wife uses the washing at present,and when shs removes the clothes their a lot of fluff on all the washed items,my wife has then to brush each item which takes a good...
TJIS DUE TO YOUR NEW WASHER SPINS AT AF FASTER RATE THAN OLD WASHER AND NFLUFF IS BEING EXTRACTED OUT OF CLOTHING IT WILL EVENTUALLY STOP AFTER A COUPLE OF WASHINGS OF EACH ARTICLE OF CLOTHING THIS IS NORMALL
Jan 24, 2011 | Whirlpool Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Jan 17, 2011 | LG WFT1071TP Top Load Washer
Clothes look drab after washing them.
Is the machine new or old? How long has this been a problem? Has this been occuring slowly or has it started suddenly? Before you give blame to the machine, I suggest you wash your clothes at a laundromat or a friend/relative washing machine to see the results you get. Also, the detergent could be partially at fault especially if you use too little or too much (too much will cause a film to build-up on the clothes that cannot be washed away enough durung rinse). IF AFTER TRYING THESE SUGGESTIONS YOU STILL HAVE THE PROBLEM, open the lid while your Maytag is washing to see if the water level is sufficient and to see if the aggitator is moving; note- you may have to open quickly and check very fast to see if there is aggitation movement because some models stop the washing if you open lid (all models stop the rinse/spin action if you open lid.Goodluck, Macgivor
Nov 09, 2009 | Maytag HAV2557 Top Load Washer
My dryer is very noisy and it vibrates a lot when it is on.
Never use a Dryer that does not run smooth!
Dryers have a knack of collecting vast amounts of clothing shed fluff which collects like a cobwebbed house a century old.!
These are fire hazards waiting to ignite.
Get a techo to check it out and quote you for a service.
Oct 20, 2009 | GE WSM2700D Top Load Stacked Washer /...
I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the...
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Oct 06, 2009 | Washing Machines
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Jun 07, 2009 | Whirlpool Washing Machines
Hi there, i have recently purchased a maytag atlantis washing machine 2nd hand model MAV7750BGW,great machine only its leaving lint on cloths and i dont have a manual for it,can you please...
To my knowledge, on most (but not all) washing machines, lint/fluff are collected on the wash cycle and flushed down with the water during drain cycle.
Since your machine is a Maytag, it is different. On most Maytag washing machines, lint/fluff is collected in the center tube of the agitator. It wold be necessary to lift out said tube and thereafter clean it on a regular basis. Some other models have a lint filter near the top of the tub, which you need to slide out, clean off, and reinsert. If for some reason there is no lint/fluff filter in your machine, this page shows how one can be made.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | Maytag Washing Machines
Black Stains on my whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 series washing machine
30 YEARS REPAIRING NEVER HEARD THAT ONE sorry i don't know
Nov 30, 2007 | Kenmore 24032\24036 Top Load Washer
Fluff left on clothing
Maytag Performa Washing Machine!!
All our clothes are being ruined with continuos fluff sticking to items.Have tried hot wash -no clothes, same problem.
Have tried not using Fabric Softener still no solution.
guest
Aug 14, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
390 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
