Question about Motorola Lands Phones
My Motorola Q keeps freezing up! I have to take the battery out and put it back in and it will power on, but freeze in about 5 seconds. I don't have any type of insurance on it. Help?
  • 38 Answers
Hello. do you have a memory card in the phone ? If you do, try deleting some of the pictures or files off of the card. if this solves your problem, then just buy a bigger memory card. If you do not have a memory card, then there is a problem with the software on the phone. try updating the software version. If that does not help, then your phone needs to be serviced. I hope this helps. Dont forget to rate me. thanks ! bye
Posted on Sep 08, 2009
Atrix screen frozen
Usually with screen freezes you would want to take back off of phone and take battery out then keep out for 2-3 minutes and then put battery back in and power on phone. If your phone keeps freezing you might want to check the memory on your phone to see how much available memory you have left to see if you have used too much memory. If your phone memory is practically full then you might want to delete some pictures or apps off the phone so the phone will work properly and not freeze. Phones are more like computers today and they need memory to operate. If these too are not working. Then I would do a full factory data reset. If your not able to go to your settings due to freezing here are instructions on how to do it while the phone is off.
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/60620/p/30,6720,7898/session/L3RpbWUvMTM2MjE4MzQ5NS9zaWQvd2hRaTY2a2w%3D
Mar 01, 2013 | Motorola Mobility ATRIX 4G (16 GB)...
My motorola xt5 is freezing with the motorola batwing on the screen
I would try power cycling the phone first. I am not familar with this particular phone, but if you can remove the battery and hold the power button in for about 30 seconds with the battery out it should do it. I would then try powering it on and seeing it freezes. I would also check to see if there are any new software updates and also if you have recently done an update that may be causing problems. You could also try doing a factory reset on the phone as a last attempt.
Feb 14, 2013 | Motorola Mobility Quench XT5 XT502...
Frozen
Hey, I had a similar problem where my krzr kept freezing up on me and i found a solution on another site. I had given up and was going to take it into a store tomorrow but this actually worked. Take the battery out and then hold the power key down for 15-30 seconds. This does a hard reboot of the phone. Then put the batter back in and turn it on. I didn't lose any of my info and it's working just fine now
Oct 23, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Motorola Q9m frozen how can I get my contacts
I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
This happened all the time until I went to the Motorola site and did full phone update ( http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
Oct 17, 2008 | Motorola Mobility Q9m Smartphone
Razr is powered on, every five seconds the screen freezes and I lose service
open the back of the phone and look right above the battery there should be a little circle if it is red...means phone has water damage. the same thing happend to my phone there is little if anything that can be done to fix the problem
Oct 09, 2008 | Motorola Mobility RAZR V3
My phone is new but all of the sudden its freezes after 5 sec of turning it on.
Either the phone has a main board issue or some file corruption - hopefully for you its just the files that need to be reflashed.
If it's the board cost can be around $150-200 depending on the repair center - flashing costs $25-40
http://horizonwirelessonline.com
Jan 20, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Freezing up
Have you had your phone updated lately if not call in to your cell phone company and ask them to do a up date on your phone and when they up date your cell phone turn off your cell phone and re-turn it back on.
If this dont work take your battery out leave out for 60 seconds and put battery back in and turn phone off and back on.
Nov 27, 2007 | Motorola Mobility V551
Motorola c290 help me
to reboot the phone... Remove the battery. Hold the power key down for 30 seconds while battery is out of phone. Replace battery, and turn on the phone.
Sep 24, 2007 | Cell Phones
Motorola V220 - Freezes
Have you done any updates to it if not connect to internet and try updates
Sep 26, 2017 | Motorola Mobility V220 Universal FM...
Lands Phones Logo
412 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
