Question about Troy-Bilt Pony Garden Tiller
Pony wont stay in drive
Same problem as another post. I have a Pony tiller that won't stay in drive, it keeps popping back to free wheel.
This is the model with the lever that you turn (as the other poster said) from about 12 oclock (free wheel) to 3 or 4 oclock for drive. This isn't a Horse model with the adjustment block.
It works fine if I hold it there with very minimal force, but I don't see how to adjust the tension to hold it there. Suggestions?
  • 26 Answers
I would check and see if your cable is binding. If it is binding you may not be getting it engaged all the way. Also you have to rock the tiller back and forth a little while you are trying to engage it or sometimes it will not engage all the way and then will pop out. Also check that the arm the cable connects to at the transmission is free to move in and out of gear. Sometimes those get coroded up. Just spray some penetrating oil on it,the cable and lthe lever. As far as I know there is not a tension adjustment on the cable.
Good Luck!
Posted on Jan 15, 2010
Troy Bilt Pony Garden tiller possibly 1982 Model Handle that controls Free Wheel and Direct Drive will not turn from Free Wheel to Direct Drive. How do I fix?
Without seeing your machine, I will have to give you a generic answer.
I am certain you answer lies in the mechanism.
I suspect either a broken part or a frozen part.
The frozen part would be stuck with rust or dirt, preventing movement.
The broken and frozen parts both will require taking the whole thing apart and servicing it.
Servicing requires cleaning, oiling, and greasing as needed.
God bless your efforts.
Jul 22, 2016 | Troy-Bilt Garden
How do you get it to free wheel
If you have the tiller I think you have, they did make provisions on some models to "freewheel" but you have to remove the retaining pin on the wheel hubs and push the wheels inward and then reinstall the pin to keep the wheel from coming off. Hope this helps.
Feb 20, 2011 | Troy-Bilt Pony Garden Tiller
1980 pony rear tine tiller: when I put it into gear it just sits there and will suddenly lurch ahead uncontrollably.
That will happen when the tines are engaged while the wheels are in Neutral as the tines simply drive the whole machine forward without the drag of the wheels being in gear. If the wheel transmission is engaged and this is still happening, then you have need for repair.
farmerbear at FixYa.com
Sep 22, 2010 | Troy-Bilt Pony Garden Tiller
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tansmission won't lock into drive. 1979 Pony
sounds like your fork lever/ shift rod is bent and flexing
Jul 04, 2010 | Troy-Bilt Pony Garden Tiller
Disassemble Troy-Bilt Econo-Horse Transmission (1991 Manufacture)
If you do not have a manual you can get it free at troybilt.com.
Apr 24, 2010 | Troy-Bilt Pony Garden Tiller
Troy Bilt Pony s/n P92695 5Hp Briggs. Drive wheels won't stay engaged. Lever jumps out. Can hold lever in with not much effort and will stay engaged. Any adjustments?
yes there is an adjustment. follow your shift lever down and you will find a block of iron with 2 bolts holding it. you will also see ond the lever itself a spring loaded pin.most of the time this pin gets gummed up and does not engage the block completely.clean and ensure the pin moves freely. if this does not solve the prob then the block can be moved up or down by loosening the bolts.
Sep 06, 2009 | Troy-Bilt Pony Garden Tiller
Troybilt pony wont go into drive.
Not technically a solution, but there are Troybuilt tiller forums out there on the net. MTD bought them out some years back and some parts are still available. I had to go thru them to find a part number for a mid 80's Horse unit that had a broken drive coupling. Anyways, they have parts breakdowns and manuals on their site. And I've seen some on ebay if you need parts.
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
7 hp pony b & s ...bolts backed out on brg. cap at tine drive gear. Replaced gear and spacers---no drive on wheels or tines. Is there a shear pin or have the brass gear(s) bit the dust? I owned this...
I did not not resolve my problem, instead I went to bed! I will tear the whole thing down and provide results when I get them. Again thanks for the support. JM
Apr 18, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
283 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
