Question about Pioneer DEH-P7000BT Car CD/ MP3 Player
Exactly the same problem as above
It connects for 3 seconds, then disconnects, then re-connects after 2 mins --- makes it unusable. HELP! My phone is past warranty, so I will have to get a new one, as Sprint and LG say this is not their problem.
    Sergeant:
    Champion:
  • 255 Answers
Replace it sorry :(
Posted on Sep 08, 2009
New pump screen filters. Will not start now.
If you are referring to fuel pump screen filters, check to make sure that you reconnected the fuel pump to it's power source. In fact, disconnect, clean the connections, and reconnect.
If the fuel system lost pressure, you may need to turn the key from off to on, wait 3 seconds, then off, then on and wait 3 seconds for a few cycles of that.
Knowing exactly what you are asking about and the year, make, and model of the vehicle would help me answer this question too.
Dec 16, 2015 | Cars & Trucks
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
Dead nokia 2700 classic usb connection disconnects automatically ?
1. Please make sure your USB cable is working fine. better to connect your phone using another USB cable.
2. Change the phone's battery, or make sure its more than 80% charged and in good condition.
3. Try to connect with different USB Port on your PC.
Hope your problem will be solved.
thanks
Dec 02, 2012 | Nokia Classic 2700 Cell Phone
Call disconnecting
With a china phone, you will always have problems.
Replace with a good nokia original phone.
Good luck.
Sep 10, 2009 | Nokia E71 Smartphone
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Lands Phones
Please tell me exactly how to put java apps and movies on the i9
Ok, Its pretty simple to add java apps/games and movies to your i9. just
1) connect your phone to your pc via the usb.
2) go into your i9 phones memory card (the first of the two letters) i.e I = phone memory , H = memory card.. so go into the H drive.
3) Create a folder call 'JAVA' and simply drag your downloaded apps/games from your pc into your 'JAVA' folder on your memory card!
4) When you disconnect you phone, go to java in your phone menu then you can install the apps/games.
(step 3 only need to create 'java' folder once)
For movies
1) repeat step 1 and 2 above ^^
2) drag the movies from your pc into 'Movies' folder on memory card
3) disconnect phone from pc and you can now watch on your phone!
Note: i9 phone supports 3GP, AVI format only.
Jan 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Dec 04, 2008 | LG Secret ? KF750 Cellular Phone
Recording Length Not As Indicated
Hi. Yeah, RCA soutions are worthless. What happens is that the hard disk loses recording time while in use. Like a hard disk losing clusters on a computer and making them unusable. To get that recording time back, you will need to reset the unit. To do this, go to the main menu, press and hold the play and open buttons on the front pannel for about 7 seconds. This will reformat your hard disk. Keep in mind that reformating will erase all data. I have looked up and down for some type of firmware/software update and RCA support told me to disconnect the unit..press the power button 10 times and connect again!!???!?!? How silly. Hope this helps :)
Jul 24, 2008 | RCA DRC8052N DVD Recorder
Cat 5 wiring
Yes you can but depending on the length of the cable, you may not be able to have a connection speed of more than 100 mbps because of the 48V phone line running along the Ethernet link. You have to understand that this is completely outside the structured networks guidelines... but it may be quite useful if you have a lack of cables. So, do that only if you really cannot add another wire without having to destroy you walls or ceilings.
Use the blue and brown pairs for the phone and green and orange pairs for the Internet. Be sure to untwist the pairs as close as possible to the connect point. For that kind of setup, I recommend you to use a BIXed wall plate such as the Belden AX100344 (2 ports) or AX100352 (4 ports).
For the Ethernet outlet, the orange and green wires would go exactly where they should: 3,4,5 and 6.
If you are using a 2 ports plate (AX100344), the blue wires will go into 1,2 and the brown will go into 3,4 of the second outlet. This will make your phone outlet carry the 2 phones lines. Some business phones actually support receiving the two phone lines like this.
If you are using a 4 ports plate (AX100352), exactly as with the 2-port plate, the blue wires will go into 1,2 of the second outlet. Then, the brown wires will go into 3,4 of the third outlet. This way, the second and third outlets will have regular phone lines in which you will be able to plug any kind of domestic phone. Unfortunately, the forth port will remain unused.
This being said, I have explained only how to connect the wall side since I don't know anything about where and how the other end is terminated.
May 06, 2008 | Computers & Internet
Cannot get PC Studio 3 to work properly
Ok.... found this on another forum, tried it and it works! Fixed my problem, which was exactly the same as yours. Unplug usb cable from phone Type *#52828378# into phone and this comes up 1 Trace setting 2 OTA type setting 3 Serial test 4 TFS reset select 3 serial test and this comes up 1 PPP UP 2 Serial download 3 Run TCK Select 2 Serial download The phone will reboot and once its rebooted connect usb cable and pc studio will work.
Oct 04, 2007 | Samsung SGH-D900 Cellular Phone
Pioneer DEH-P7000BT Car CD/ MP3 Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
