Home | Hampton Bay | 24750 Huntington III Ceiling Fan | Ceiling fan stuck on hig...
Hampton Bay 24750 Huntington III Ceiling Fan
Problem for Hampton Bay 24750 Huntington III Ceiling Fan
Ceiling fan stuck on high.
By jonahmust871 on Sep 08, 2009
3 months ago, I broke the fan chain completly from the ceiling fan in the dining room, leaving it off, causing me to call it broken, and last week, my son sticked the nails in the chain hole using the stick and the fan went on high, and he stopped. My son might be the youngest person who ever fixed ceiling fan. I have on/off switch which control both light and fan.I need help fixing the chain and taking nails out so I can use them. It's annoying in winter for the fan to be stuck on high while the switch controls both fan and light at night time. While eating in winter, I don't the cold air moving and I don't want the room to be dark.
Comments:
Sep 09, 2009
- The electricion fixed the chain and pulled the nail out of the old chain switch. Now I can put it on any 3 speed. I hope I don't break the chain again.
Sep 20, 2009
- My daughter kept flattening the tire on my son's bike so he went into her room and took all of the nails and started sticking them in the chain hole. The fan started blowing all of the paper off of the pile and made a huge mess. I had to clean up and I missed the train to the meeting. What a domino effect and I missed a train because of my daughter.
Best Solution
posted on Sep 14, 2009
Very Helpful)
sixholdens
Rank: Wiz
Rating: 84%, 47 votes
I think he/she means that the wall switch controls both so only need to replace the broken fan switch. The people at the hardware store should be able to match your switch up with a new one.
Make sure you turn off the breaker that powers the fan and light before you take it apart!!
You son is lucky he didn't get shocked or worse....
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Noe I have a new chain " - jonahmust871
Solution #2
posted on Sep 08, 2009
Very Helpful)
protek480
Rank: Guru
Rating: 86%, 488 votes
The fan usually has two holes for separate switch control. See if there is another hole on the opposite side that a switch can be added for separate control. Then go to the hardware store and buy fan switch with pull chain. Ask for help finding them, they have them in the special switch section of lamp parts. Install new switch (es) and wire the one the way it is. Add the new one and take the light or fan wire out from the old switch and put it to the new switch.
Was this helpful?
Yes
No
Asker's Testimonial
" I bought a chain switch and called the electriction to fix the chain so the fan can be medium or low, or off when the light is on. " - jonahmust871
Popular Solutions for Hampton Bay 24750 Huntington
Questions and Unsolved Problems for Hampton Bay 24750 Huntington
Do you recommend Hampton Bay 24750 Huntington III Ceiling Fan?
Answer
Answer
Hampton bay with black wire powered remote. Fan works fine, but light is very dim. Tried... (More)
Answer
Severe wobble on high speed only. I tried balancing with kit supplied with fan with no improvement.... (More)
Answer
fan stopped working received new part from Hampton need installation manual, need wiring diagram and... (More)
Answer
I have a hampton bay 445994 which is a brass/nickel light fixture for indoors with the white globe... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hampton Bay 24750 Huntington...:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
