Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Refrigerator maytag bottom mount with ice and water in door unit not cooling but ice dispencer door keeps opening and closing by itself
  • Anonymous Jan 05, 2008
    plugging and un plugging
  • Anonymous Mar 25, 2014
    UNIT IS NOISY AND WHEN REFRIGERATOR DOOR IS OPENED THE UNIT QUITS. WHEN UPWARD PRESSURE IS ON DOOR THE UNIT STAYS RUNNING
Should the water supply to the ice maker and door be from the cold water house supply?
Posted on Dec 23, 2007
  • 410 Answers
It has a bad main control board call maytag they will most likely repair it in warranty for you
Posted on Dec 11, 2007
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Door inside the ice dispencer sticks open. have to push it close
Sounds like the clear plastic door guide on the ice dispensor arm , is broken loose , holding the door , keeping it from closing . If this is the problem , it just snaps on . If a piece is broken from the guide , pt # 985866 is usually the part .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Maytat side by side with ice/water in the door is stuck on the water and will not push to the ice setting?
This is probably your switch or the button is frozen in the water position. I would check the ice dispensor inside the door first and see if there is ice built up on it. If so, you can run warm water over it with a pan under it to catch the water. If this is not it, call us and we will ship the switch to you. We will need your model number. Hope this answers your questions and resolves your issue. :>)
Aug 25, 2009 | Maytag 23 cu. ft. Side-by-Side...
Matag fridge msd2351hew icemaker ice and water work and cubes come of crushed ice dispencer. There is a capacitor connected to auger motor.Is this the problem? There are no other electrical parts.
If you remove the bin and look on the bottom of it you will see a rod running from front to back,this opens and closes the crusher see if it moves freely, if not dump the ice and rinse the bin out with hot water till it moves freely,if so,with the door open set the dispenser to cubes leave the bin out push the light switch in and hit the  dispenser button you should hear a loud pop and see the actuator by the auger motor move up,and drop down when you release it.
Aug 22, 2009 | Maytag Refrigerators
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Jan 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
169 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
