Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
I am having a problem removing the water filter...it seems stuck.
    Sergeant:
    Champion:
  • 255 Answers
Where is it located ? inside, is it froze ? some are just hard to get off turn a little harder it wont break.
Posted on Sep 08, 2009
Cannot get ice & water filter out in order to install new one. Following directions, seems to be stuck.
Try this. Shut off the water supply, and try to dispense water. This will eliminate water pressure on the filter and allow easier removal. With water pressure in place, you are having to try to overcome water pressure and requires a lot more effort.
If this does not work you may need to find out if your refrigerator manufacturer has a special wrench to help removal of filter.
Hope this helps.
Dec 13, 2014 | Maytag Refrigerators
I can not get the filter holder to twist off.. It seems to be stuck
Hello friend, thank you for your post!
I understand that your water filter holder is stuck and will not come off of your Frigidaire refrigerator. I see you have the Pure Source filter and after reviewing that it does not appear to have a filter holder. To remove that filter you should have to push it in and it should discharge. If it is not doing so, I would push it in and turn it slightly to remove it. If you are still having trouble with your filter removal could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the inside of your refrigerator normally on the right hand wall. I look forward to assisting you. -Matt
Aug 23, 2014 | Frigidaire Refrigerators
I can't seem to remove filter the cap came off but I can't seem to get filter out
With the cap off the filer was not turned far enough for it to clear the locks. Grab the filter with a pair of pliers and turn it to the unlock position then pull it out.
Aug 14, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
How do u clean filter
Spa filters are put into a spa one of two ways. They have threads on the underside of the filter element and thread into place by unthreading it or the filter is simply pressed into place and to remove it you just pull up. It can be fairly heavy either way because all those pleats hold quite a bit of water when initially pulling it out of the water.
Rod
US Parts Center
888-521-6183
Mar 23, 2014 | Home
Can't get the air filter out. Seems to be stuck.
As you already know, the air intake filter is behind the water collection bucket. Once you have removed the bucket, grasp the filter frame at the bottom, pull down and out. The filter frame is made to fit snugly, so pull it out gingerly.
Hope this helped you get the filter removed. Please let me know. Thanks.
Jun 06, 2011 | Kenmore 54501 Dehumidifier
The place where the water filter goes in won't open so I can't replace the water filter. It will not turn the 1/4 turn to the left as per the instructions. It seems stuck.
Hi there
These caps can be very stubborn to remove, the 'o' ring seal can almost lock it into place.
There are 2 things you can try
Switch off and unplug the fridge
Switch off the water supply and open the dispense valve
1. Use a hair drier to warm the cap, be careful as this can get very hot, you may choose to use gloves if it seems very hot, be careful not to overheat as this can distort the cap.Then twist anticlockwise and pull to remove the filter cap.
2. Put a shallow tray on the floor below the filter and cap, carefully and slowly pour hot (not boiling) water over the can then ,wearing gloves, twist anticlockwise then pull to remove the cap.
You may need to persevere if the filter has not been changed before.
Having changed the filter then plug in the unit and switch on the power and water and draw off water from the dispense valve in 5 second burst for about 2 mins to remove air from the filter and ensure that clean water is right through the fridge
Hope this helps
Gordon
Apr 22, 2011 | KitchenAid (KSRD22FKST) Side by Side...
GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Change Kenmore fridge water filter due to slow water dispenser
what you want to look for on the filter is an arrow turn the arrow left and then pull down
Dec 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Jun 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
