Question about Car Audio & Video
Car subwoofer wont play loud
MTX subwoofer, pioneer amp. Sub playssound, but sound level is low coming from sub. Worked fine but now the sound level dropped. Connections are good, rechecked adjustments, gain, head unit etc... all looks good. When you turn the gain up it gets louder but not even close to where it used to be.I usually have it set at normal, but if i turned it all the way before it used to shake the car. now even with the gain all the way up its not even to where it was at the normal setting. If you take the rca's at the amp and unplug the left no change. unplug the right. no sound. so i checked the left and right rca's and plug in each one into the left input i get sound so i know both left and right rca's work. just no power behind it anymore. Im guessing the prob is with the amp, but i dont know if its a fuse or if its going bad or what.
  • 434 Answers
You blew up a channel in your amp. Being that it's a Pioneer amp, I would throw it away and get another.
Posted on Sep 08, 2009
No sound from subwoofer
From somneone on the AVS-forum I got the tip to set the front speakers to small. After checking this (it was set) I looked after the sub (a Fostex PMsub) again and turned the volume really high - and now it works! Of course I have tested the sub on another output (other amp and zone2-out on the Onkyo) and it worked with a relatively low setting. So it seems, that the sub-out is just very low level, but working OK.
hth
Karl
Dec 05, 2012 | Pioneer VSXD814 Receiver
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Had the subwoofer tested at an audio shop but they wanted to sell me a woofer. It makes no sound at all. A power issue? there was no problems with the 300 watt Kicker amp.
if the speaker cone moves it should produce some sound if it doesn't move when power is applied then the voice coil is frozen.
not really a power issue unless its a "powered sub" and if that's the case then you should not be running in high level sound using speaker wire (especially off a 300 w amp) but instead a low level signal via RCA cable.
Dec 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Constant pounding of subwoofer
Have you tried another pair of RCA's? Sounds like you have a bad pair of them.
Feb 07, 2009 | MTX RT2200 Car Audio Amplifier
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Sub doesnt sound loud
try to change subs with your friend to find out if the problem is on amplifier or on sub wofer
Nov 21, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Subwoofer
Your overdriving the Subs and burning up the voice coils. Its really not worth fixing. It almost costs the same to fix as to buy a new one. Set you Amp gain down low. Then crank up the volume with a bass test. Slowly crank up the gain until you get some distortion. Then reduce the gain slightly. You will be set then to crank it up to the distortion level and not blow you speakers. Open a can of whoopass on anyne the cranks up on your gain. It will be costing you another set of MTX's.
Oct 31, 2007 | Car Audio & Video
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
Car Audio & Video Logo
313 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
