Question about Cell Phones
I have a RIM7250VPC cigarette lighter transformer. I want to figure out if it will provide appropriate power for an electric device I own. Do you know what power this adapter delivers?
Mercedes C200 Classic W202
there is a device on the market that plugs into the cigarette lighter socket from which you can charge the car battery
it has a small 12 v battery in it and this gives a voltage to activate the car battery
try auto spare shops and battery shops for it
it may also be available fro a good tool shop in the battery and elecrical section
May 22, 2015 | GPS
My cigarette lighter socket quit working. I have no idea why. I can't figure out which fuse it is
using a test light check for power and ground for the lighter socket. if this is good then then you know the fuse is good. this indicates that you need to replace the cigarette lighter element. the part that gets hot when you want to light a cigarette.
Apr 11, 2015 | Cars & Trucks
Cigarette Lighter Outlet Doesn't Work; Fuse Still Intact
If the cigarette lighter has been in use for cigarettes ... it could be that the contacts within lighter outlet contact points are heat damaged and connection to auxiliary device may not be made electrically ... You could test if you had a voltmeter ... but if you can visibly see heat damage... perhaps you could try scratching any obvious tarnished metal contact point with screw driver... . (the central contact point is the one that is likely to be tarnished requiring cleaning) unless it is a loose electrical conection gone bad... but that would require removing the cigarette lighter.
Note: recommend to remove the cigarette lighter fuse before attempting to insert a metal object into the cigarette lighter... else sparks may fly and the fuse will/or should blow.
good luck.
Feb 27, 2015 | Volkswagen 2006-2010 Jetta TDI Steering...
Cigarette lighters not working
Check for power at fuse. If power is there a break in the wire going to cig lighter is broken. If no power than there is a blown fusible link by battery. Check fuses under hood also
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Jan 23, 2013 | 2005 Buick LaCrosse
The cigarett lighter outlets do not work.
Most likely you have something metallic that entered/fell inside one of the cigarette lighters.
I once found a dime inside a cigarette lighter which my children assured me was placed there by a shadowy personage named "Notme". Go figure.
While the fuse is REMOVED, look inside each lighter with a flashlight and remove the foreign material.
If you find nothing inside the lighters, disconnect them all from the electrical system by removing the single wire attached to the rear of the lighters. Replace the fuse.
Alternately, you can disconnect them one at a time, replacing the fuse after each one. You may need a few fuses for this.
If the fuse blows after ALL the lighters are disconnected, you have a wiring short circuit which is best diagnosed by a professional.
If the fuse does not blow, begin reconnecting the lighters until you see a spark, or the fuse blows again. This is the faulty lighter, replace it and your problem is solved.
Note: You cannot get shocked or electrocuted by your car's 12 Volt system but you can be burned by heavy sparking. You can reduce the risk of heavy sparking by using a lower-rated fuse during the testing. Wear saftey goggles and latex gloves for safety.
Good luck
Jul 03, 2009 | 2001 Pontiac Grand Prix
No power going to cigarette lighter in Nissan Murano '05
I troubleshot this issue and found the problem to be a defective power plug. There was no connection from the ground spade lug to the receptacle. The fix is easy. Just remove the plug, unplug the electrical connector and replace the bad unit. I found a similar one at Wal-Mart for under $6 that had a compatible electrical contact configuration.
This seems to be a design problem with the power plug. There are no visible signs of contact burn or corrosion... simply an open on the ground side of the housing.
May 27, 2009 | 2005 Nissan Murano
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
Cell Phones Logo
119 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
