Question about Maytag Neptune MAH5500B Front Load Washer
Washer is leaving dirty spots on clothes
After coming out of the washer, there are spots that are on the clothes that look like dirt or mud spots. They get dried on in the dryer and then do not come out at all. I notice that there is dirt around the inside of the washer tub (front loader).....,could there be a build up of dirt around the tub that gets released during the wash cycle and gets on the clothes?
  • 135 Answers
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Posted on Sep 08, 2009
Ken more washer leaves dirty marks on clothes
Pull the agitator out and clean the inside of it and the area of the tub that it covers. A buildup of crud won't be removed by simply washing out the machine. Rinsing out a frying pan will get a lot of the dirt out but, it must be properly washed to get it all.
Jan 20, 2013 | Washing Machines
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
Odor coming from washer and sometimes dirt and grime in tub
Hello.
Your washer needs a cleansing. To do this be sure there are no clothes in the washer. Pour in two cups of white vinegar. Run the washer on the fullest water and hottest setting. This will clean it thoroughly. Repeat if necessary. J.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Leaving dirty marks on clothing
Try removing the water hoses and find the screens in each end.. If clogged with gunk - that could be the culpret..
Jul 23, 2009 | Washing Machines
My kenmore washer leaves fleece and dirt on my clothes always
Nwanne,
It truly sounds like you have something in the washer that may be trapped.
I would remove the lint trap and make certain it is cleaned. Then check under the rim of the washer between the upper tub and the upper seal area. And lastly, check between the agitator bottom and the tub.
There really isn't any part of the washing machine that will produce "fleece" so I believe you have an article of clothing that is trapped.
Good luck and let me know.
Regards
May 14, 2009 | Kenmore Washing Machines
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
823 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
