Question about Samsung PCH521R 52" Rear Projection Television
My Green is out of alignment
I can use the converge feature but the green is messed up . I see two of everyb thing one in green.
Please help me.
  • 80 Answers
You need new convergence chips, part number stk-392-020 or stk 392-040, very common problem, it may also have blown micro fuses, you need and ohm meter and some soldering skills to fix this.
Posted on Sep 08, 2009
Blurred picture red and blue shadows
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are dis aligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to refer to the manual on how to go about it
Nov 29, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
I HAVE A DOUBLE VISION, BETWEEN THE GREEN AND RED, THE GREEN IS SOMEWHAT WARPED OR ARCHED.
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Jun 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
The screen is all messed up! It has green and
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2010 | Sony KP-51WS510 51" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 50h81 2001 rear projection hdtv ONLY SHOWS GREEN! PLEASE HELP!
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Toshiba 50H81 50" Rear Projection...
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Bill
Dec 09, 2007 | Samsung HCM4216W 42" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung PCH521R 52" Rear Projection Television Logo
166 people viewed this question
Jerry Greenberg
Jerry Greenberg
