Question about Akai CF2791 27" TV
Why tv only goes 1-13
Tv only palys1-13 without cabel box
  • 556 Answers
You have got it in the off air mode you have to go into the menu where you auto program it and change it to cable mode.
Posted on Sep 08, 2009
Lost my manual I need to hook up to my cabel box. plus what cabels i need for my dvw5000
here is a basic diagram of cable connection from a cable box to a vcr and to the tv.diagrams_hookup_tv_dvd_cabl.jpg diagrams_hookup_tv_dvd_cabl.jpg
Feb 06, 2011 | Sanyo DVW-5000 DVD Player/VCR
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
I purchased a 32 inch flat screen coby tv on 11/2010. I am trying to advance the channels with the right up and down channel button on the remote, but it only goes to favorites. I only want to advance...
Are you using the cable box remote on the cable box or the coby remote on the cable box? or are you using the cable box remote on the TV or the coby remote on the TV? Try using the coby remote on the TV without the cable box connected first to see if the remote even works on the TV, replace the batteries and retry. then try the cable box remote on the TV to see if you have it set up correctly for that TV. Sometimes when you reprogram a remote to work other devices the buttons won't always end up working the commands that are labled on the remote, also there is more than 1 code that may work better than other codes or may match up with the labeled keys more closely. Low batteries will also make a remote act strangely.make sure the batteries also make good contact on the pins or metal pieces inside the remote. I guess I need more info on which remotes are being used for what purpose before I could give a more certain answer.
Dec 26, 2010 | LG Televison & Video
Can i access my digital channels on cabel without a box? I dont want to have to type in sub numbers, can my remote be programed for that?
Local digital channels should be available from the cable TV line from the wall. Your TV has to have a digital tuner. You can do a channel set-up scan with the TV. Then do channel up and down or channel # access to get to desired channel.
Apr 14, 2010 | Televison & Video
No signal to tv
your av cabeles could be on the wrong setting try to change from hdmi to tv on the end of the av cable that goes into the xbox. if it still dosent work then try to change the imoprt slots or try your cabels on another tv to see if its your cables thats the problem if you get signal on the other tv then its your first tv. but if you dont your av cabels mite be going i sugjest buying a new set if the other options dont work
Dec 11, 2009 | Microsoft Xbox 360 Console
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
What is a cabel card
A cablecard is the size of a credit card use to view or record digital cable channels on a digital recorder,personal computers and tv s without the use of outside equipment like (stb) set top box provided by your cable company, below is a picture of one hope this helps.
Aug 12, 2009 | Zenith Z37LZ5D 37 in. LCD TV
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
PICTURE TURNS BALCK WHITE WITH DVD,VHS OR SET UP BOX
Make sure that your external devices are PAL. If they are sending out the NTSC standard, the picture will be there without color as you are seeing.
Dan
May 11, 2009 | Televison & Video
56 inch Panasonic Projection TV
Hello stonehor,
Do a quick check on your cable wire. Make sure they are all pushed in properly both on the cable box and on the TV connector. What we have found is that these cable are not pushed in all the way. If this happened on both component input, you may have an open connection further back on that input board.
Best regards
circuitcity
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Akai CF2791 27" TV Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
