Question about Motorola Mobility RAZR V3
When i cut it on it stays on helomoto
What should i do?
I have a 2000 chevrolet impala done had 3 sensors put on it still want stay started crank it up and it cuts right off
Check for good fuel flows. Stay with simple fix ideas first B4 believing in costly "fixes".
Dec 10, 2013 | Chevrolet Impala Cars & Trucks
What make's a gas oven stay on when it's cut off?
Did it stay on for long after you turned the gas off? Maybe it was just the remainder of the gas running through the oven
Oct 31, 2013 | Ovens
My V323i will not boot. Sometimes get helomoto logo and nothing else. Sometimes just white screen.
Either the flip assembly has a problem with the ribbon cable and needs a flip assembly replacement or the LCD screen is defective, replace the flip assembly if not its the main board, either case the phone has to be swapped or replaced ( flip assembly first if not then whole phone or main board.
Good luck and please rate and vote for me if I was of any help. Thanks.
Jun 15, 2010 | Motorola Mobility V323i Cellular Phone
My cell won't open! When i try to open ceel by pushing hang off (red) button, i see logo HELOMOTO and after phone shut off.
You will need to flash your phone. You will need the flash file for your w385 and the program and the data cable you can download rsd lite and the flash file from mobile-files.com. You may also need a program called winrar. This program will allow you to open .rar files.
Dec 09, 2009 | Motorola Mobility W385 Cellular Phone
Auto dry cycle will not cut off. It stays on even
yes it has or maybe heat senson the side of the heating coil
Oct 23, 2009 | General Electric DHDSR46EGWW Dryer
Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Feb 01, 2009 | Dometic RM2652 Refrigerator
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Can get razr to work
Try booting the phone without your SIM card in and see if the results change. If so, contact your carrier and tell them you have a corrupt SIM card.
Dec 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
