my new computer does not have lpt1 port..so i change it to usb port for my panasonic kx-p1121..the problem is i only can print a microsoft office program but not for my MS-DOS program..please anybody help me..
hi solution may be simple: back in the times of DOS USB was not up to date, so older applications(if run in DOS mode) may not b ebale to address the usb port.
it says i have to download a high speed usb controller for my wireless usb adapter for it to be...
(More)
it says i have to download a high speed usb controller for my wireless usb adapter for it to be faster. i have a dell where do i get this download
On IMac OS 10.4 The printer gave me the choice of printing both sides.
On )S 10.6 that choice has...
(More)
On )S 10.6 that choice has disappeared.
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. WHAT I HAVE TRIED, FOLLOWING EARLIER FIXYA SUGGESTIONS since then. I have. 1. turned printer upside down 2. gently cleaned out paper dust on either side of the paper rollers 3. checked that paper roller is still rough 4. tried to change to feed from lower cassette. will not accept feed switch command 5. removed and reinstalled print head (which was replaced last month) PROBLEM REMAINS. turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. QUESTION: WHAT TO DO? Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will
pass through the machine but paper jam message continues. QUESTION: Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low...
(More)
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low memory
