Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda does not clean the entire pool. Seems to be stuck in a certain pattern
  • 990 Answers
If you change the direction on your return eyeballs you will change the current in the pool that could be stopping the cleaner from having free roam. Set them give half an hour then ck it again. Keep this till you see the results you want.
Posted on Oct 04, 2009
Baracuda only cleans side of pool how to clean entire pool surface
most of the time that auto pool cleaners "Head for the side" its because customer has set speed too high , need to slow down , consult your owners manual for specfic methods on how to do this , in this case slowest wins the race!!!
Sep 27, 2014 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda stopped working. it is not vibrating but
Could be a small rock or stick stuck in the diaprahm. If you pull the head you can look down both ends, use a ling stick or wire to clear or take the unit apart to find and clear this.
Aug 01, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
How to change the cleaning pattern on a barracuda g4
The g4 is a random cleaner. That means it just goes all different ways. If you reverse the hoses it will travel in a different pattern. Also, if you add or subtract one hose the pattern will change.
May 12, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My baracuda g4 is not moving and the head of it has a hole from getting stuck in my pool stairs. Does anybody has a solution for this problem or I'm the only one with this problem. Thank you
You will need to get your head rebuilt at a pool store. But the problem with it getting stuck in the stairs is from currents that develope in the water. So you will need to redirect the clean water returns so they aim down into the pool and away from the stairs. This should fix the root cause as it were.
Apr 25, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda gets stuck
Usually this can be fixed by redirecting thr returns in the pool down the wall or anywhere that will break up any currents in the pool.
Dec 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Unit patterns, does not clean entire pool
Try moving your returns to break any current in the pool. Angle them down the wall or twards steps to let the cleaner get past the currents. Hope this helps.
Dec 17, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Hello,I just hooked my Baracuda G3 up today.I feel like I followed directions and it does travel around the pool.However it follows the same track each time in a somewhat figure 8 pattern and only cleans...
Try changing the angle of your return jets in the pool they will have a tendency to set a current running in the pool. This was always what you wanted before to get the water to run past the skimmer but now it will give the cleaner a hard time getting around the pool. If you don't have directionals on you returns Baracuda makes an aftermarket dirvirter to fit most returns.
Oct 11, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Baracuda pool cleaner does not cover the entire pool
With these pool cleaners, there are several things that it could be. Check the return line water flow and redirect as necessary with an eyeball diverter. Make sure the automatic regulator valve is installed properly and is not clogged. Make sure the cleaner has proper hose balance.
Jul 01, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
580 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
