Question about Nikon COOLPIX L3 Digital Camera
My lens doesnt open
What will i do if the lens of my nikon coolpix l3 dont want to open
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 31, 2012
bmwrider
  • 215 Answers
SOURCE: Lens problems
This is an awkward one. If you were clever enough to replace or repair the lens assembly you wouldn't be writing here so all I can advise is to have a very close look at the lens and see if you can notice any slight variation in it's positioning. If you can see part of the lens is pushed slightly to the left then with a very fine blade lever the lens from the left to the right and at the same time switching on. It's often easier to get someone else to do the switching on and off for you. Make sure the batteries are fully charged too. If you can get the lens to come out a little way then keep trying and it's possible it will realign and start working. Of course it's possible you've fractured a nylon gear or two so that will be a specialist job. All I can tell you is that if you can't get the thing to work yourself it's going to be very expensive. Maybe another check on Ebay for a transplant possibility. BMW
Posted on Jul 28, 2006
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Posted on Jun 21, 2008
dlundmark
  • 797 Answers
SOURCE: nikon coolpix l3 lens error
LENS ERROR simply means there is a problem with the lens.
If the description is more detailed it would help.
Type of camera in the post always will help.
When the error started is helpful as well as how long you had the camera, as how it has been treated, did it ever get dropped, or had an impact of any kind?
Remember that digital cameras are very fragile, and should always be treated as if they are eggs, so to speak. Also the LCD is very easy to break if thrown into a purse, or some other carry bag. The camera should always be used with the wrist strap around the wrist, and put back into a padded case when done.
Lens errors can result in a number of problems.
The lens may be out of sync, or the guides internally could be off track.
Some of the internal parts, such as the gears could be broken (you will usually notice a grinding or other noise if this is the case).
There could be some dirt or sand in the track, thus causing the lens to stop or jam.
If the lens is cocked to one side, that is usually the result of an impact when the lens is extended. Sometimes this can be fixed by gently pushing the opposite direction when starting the camera.
Take care,
Posted on Jul 26, 2008
SOURCE: Lens Error on Nikon Coolpix
Sometimes removing the batteries for a day may correct the problem temporarily. But the real problem is really in the lens mechanism. "Lens error"can only be repaired by Nikon or an authorized repairman. I sent mine back in Dec. 2007. It was repaired free of free of charge under the warranty. It was fixed and returned very fast.
The same problem just reoccurred and I sent it back to Nikon this very morning. They told me this is not a problem with this model, but I beg to differ. My internet search revealed that this apparently is a problem with many Nikon lens mechanisms.
Posted on Apr 15, 2009
  • 11967 Answers
SOURCE: Nikon l3 lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 01, 2010
My camera {nikon coolpix l3}
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 24, 2008 | Nikon COOLPIX S200 Digital Camera
If the lens was bumped or hit when it was out, it could have been damaged beyond repair (internal parts broken). It may be able to be pushed into position...see my posts on this problem and possible fix.
If you cannot turn it on and cannot turn it off... well, not sure. Some cameras will not continue when it detects an error in the system anywhere. Others are more tolerant.
Jun 08, 2008 | Nikon COOLPIX L3 Digital Camera
NIKON COOLPIX L3
See my posts on this problem. By forcing the lens with you fingers into the camera, it may put it on track. This can damage the camera even further, but may be worth a try. You can try to pull it out when starting, and then pushing in on turning it off.
Worth a try, may work.
Apr 12, 2008 | Nikon COOLPIX L3 Digital Camera
Lens stuck in the out position
Please reload the Firmware and your problem will be solved.
Nov 23, 2007 | Nikon COOLPIX L3 Digital Camera
Lens Error.
nikon coolpix 4 lens error help!
Nov 11, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
96 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
